Old 02-09-2016, 10:36 PM   #1
Bigdav160
Bigdav160's Avatar
Help me with my Bucket Seat install
Ok, not the mounting. I have that part figured out.
The seat covers and foam were totally trashed. I did manage to save the springs and most of the listing wires. Now I don't remember where they go.
Well, a couple of them I do
The long ones (not pictured) go on the bottom edge of the bottom cover. The squiggly ones go on the back edges, pretty sure.
I'm sort of stumped on the 4 rectangles. And I seem to have more of the straight ones than places to put them.
Perhaps my Acme seat covers do not have the same number of listing sleeves to accept the wires? The PUI foam has a couple wires embedded in them.
Should I try and attach the hog rings and connect the listing wire directly to the wire in the foam?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-09-2016, 11:12 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Help me with my Bucket Seat install
Have you checked the replacement foam for fit before you start ?
The horseshoe shaped wires are for the face side of the backrest
The four longest wires are for the seat face
And the wires once installed in the listing sleeves are then attached to the foam using hog rings
BE CAREFUL NOT TO GO THRU THE FACE MATERIAL WHEN INSTALLING HOG RINGS ONLY THRU THE LISTING
Post a few pictures of your seat covers front and back
Laying out the wires on the foam first works so you can see where they go
TOP/BACKREST
slide them into the listing sleeve with the cover inside out ,
then with the cover lying on top of the foam
find the center of the cover and the foam and install one hog ring and work your way down both sides keeping them about 3"- 4" apart
The covers are installed inside out and once you have the listings hog rung then the cover is folded face side out and the bottom and back side can be rung .
Grumpy old man is offline   Reply With Quote
