Old 02-09-2016, 10:48 PM   #1
luke1968c10
luke1968c10's Avatar
'68 Chevy pulsation while driving.
I have a 1968 Chevy C10 250 six cylinder 3 speed on the column. It has been in my family from 1973 and the odometer has returned to 00000.0 four times so now it has 591000 miles on it(engine was rebuilt at 567000 but everything else is original.) It is mostly stock but I recently replaced the points with an HEI distributor. It has a pulsation that coincides with the speed of the wheels turning. It occurs in all gears and goes away when I press the clutch or go to neutral. There is no noise associated with it. I have replaced all four brakes also replaced front wheel bearings. I topped off the oil in the transmission and the rear end. I can usually figure out any problems with this truck but this one has got me. Thank you in advance.
luke1968c10 is offline   Reply With Quote
Old 02-09-2016, 10:54 PM   #2
snipescastle2
snipescastle2's Avatar
Talking Re: '68 Chevy pulsation while driving.
Drive shaft throw a balance weight maybe? Or does the carrier bearing appear to be bad?
That's my guess....not sure.
Ben
snipescastle2 is offline   Reply With Quote
Old 02-09-2016, 11:16 PM   #3
luke1968c10
Its a short bed so no carrier bearing, but the weight on the driveshaft is something I'll have to check. I suppose there should be some remains of whatever held the weight on. Thanks for the reply.
Old 02-09-2016, 11:24 PM   #4
sloth454
sloth454's Avatar
sounds like it ether threw the balance weight off the drive shaft or you could have u-joints going bad. Do you feel it in the seat or through the steering wheel?
sloth454 is offline   Reply With Quote
Old 02-09-2016, 11:29 PM   #5
Grumpy old man
Grumpy old man's Avatar
it's a drive line / clutch issue if it goes away when the clutch is pressed or placed in neutral . Have you checked the universal joints lately ? Also with that many miles it could be front yoke slop ...
Grumpy old man is offline   Reply With Quote
Old 02-09-2016, 11:35 PM   #6
luke1968c10
I feel it in the seat. The u joints are fairly new I replaced the rear about three months ago and the front last spring. I didn't notice if it went back in in the same position(could have been turned 180 degrees.) Could that make a difference?
Old 02-10-2016, 12:30 AM   #7
sloth454
sloth454's Avatar
ok. And if you got the yoke miss aligned it will cause a vibration because the joints wont be "flexing" in sync. Did it start right after you did the joints or has this been an ongoing problem for a while? Worse case its possible something in the transmission could be coming apart.
Old 02-10-2016, 08:36 AM   #8
luke1968c10
It started out as barely noticable so I'm not absolutely sure when it started. t has been getting gradually worse over time. I suppose I could try taking the drifeshaft off and turning it 180 and trying it out. If it's a transmission problem wouldn't it make noise? Really hope it's not the tranny, I'm sure those transmissions aren't just laying around everywhere anymore!
Old 02-10-2016, 08:48 AM   #9
Grumpy old man
You won't have too much of a problem finding a three speed cheap with so many guys going for 4-5 speeds and automatics . Just a few short years ago you couldn't give away a 250 6 with a 3 speed ,Now guys are buying them to put the trucks BACK to stock.
Old 02-10-2016, 09:43 AM   #10
snipescastle2
You can try placing a worm screw hose clamp around the drive shaft and try driving a short distance, see what it does. Then re-clock the clamp at a different position, 6,9,12, 1 o'clock,etc. If it gets better, great, if worse, keep adjusting the clamp to see if its any better.
The weights they put on the shaft were spot welded, and as time goes by, they rust off.....
Hth,
Ben
Old 02-10-2016, 10:30 AM   #11
67 chevelle
67 chevelle's Avatar
couple of guesses , clutch / presureplate , and pinion bearing .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-10-2016, 10:42 AM   #12
luke1968c10
Hth,
Ben
Thanks, I'll try that. I wouldn't have thought of the worm clamp.
Old 02-10-2016, 11:19 AM   #13
JMD
JMD's Avatar
Wouldn't the fact that the problem goes away with the clutch disengaged or in neutral rule out a u-joint problem? The driveshaft is still turning regardless of whether or not it's being driven by the engine...
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 02-10-2016, 07:45 PM   #14
hamjet
hamjet's Avatar
It would most likely be the rear end pinion bearing, parts in the rear end, tranny output shaft or ujoints if it coincides with truck speed.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
