Old 02-09-2016, 11:59 PM   #1
Joesprocket
fluid in overflow tank different from radiator green
Hey everyone, quick question about coolant fluids.
I'm getting ready to replace my temp gauge sending unit and to do so I'll need to drain the coolant from the radiator petcock. The fluid in the radiator is fluorescent green however the fluid in the reserve tank is orange...like GM Dexcool orange. I've had the truck a little over a year and this is how it came. Anybody have a guess as to why the 2 different fluids? They should both be the same no?
I appreciate the help for the 'new guy'.
Joesprocket is offline   Reply With Quote
Old 02-10-2016, 09:25 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: fluid in overflow tank different from radiator green
It's not dex-cool it's probably rust , Dex-cool just causes problems with aluminum heads and radiators .I wouldn't buy it for any car/truck .
http://www.consumeraffairs.com/news0...m_dexcool.html
Grumpy old man is offline   Reply With Quote
Old 02-10-2016, 10:20 AM   #3
geezer#99
geezer#99's Avatar
Or the different colors might be because your overflow tank isn't returning the coolant to the rad when it cools down.
It's just sat there for a year turning ugly brown.
The return hose needs to be immersed in the liquid.
geezer#99 is online now   Reply With Quote
Old 02-10-2016, 02:39 PM   #4
Joesprocket
thanks! the return hose is definitely submerged but perhaps you're right that coolant isn't being returned for some reason.
I'm going to start by draining the system and replacing the temp gauge sender. Then refilling both tanks and see where that gets me.
If only i could find the correct sensor. Looks like sunpro has discontinued them.
Old 02-10-2016, 05:08 PM   #5
BLT gmc
Make sure you have the correct radiator cap, so the overflow system can work as intended. Take care, Bruce
BLT gmc is offline   Reply With Quote
Old 02-10-2016, 06:04 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Dex Cool will turn into a sludge, if exposed to air and it sits for a period of time. Flush the collection can and fill with green and mix what you need in the radiator at the proper mix.
Frank
piecesparts is offline   Reply With Quote
