Maxi fuses instead of fusible links ?
My 80 C10 has copper stranded wire replacing the fusible links at the starter and I'm thinking of addng some maxi fuses to provide some short protection . Has anyone here done this ? Thoughts ?
#2 | |
Re: Maxi fuses instead of fusible links ?
It's definitely a good idea to put some protection (fuse, fusible link, etc) back in place.
I prefer to stay with fusible links for this type of application though. Especially down near the starter where there isn't a whole lot of room to add a fuse holder. Also see http://whiteproducts.com/fusible-faqs.shtml Quote:
This is just my 2 cents but I have been replacing fusible links with maxi fuses for a while.
I also do not take the power from the starter anymore when I wire something. I have been running the power from the battery to a junction block with 8 gauge wire or bigger depending on what I am wiring. The only thing going down to the starter is a cable and the solenoid wire. I think it is safer and a better system. If you read a Ron Francis catalog they have electrical tips in it that also state that a fusible link is a very poor choice for protection. |
Moderator
![]() Join Date: Oct 2008
I'm with Ray on this. Don't change from fusible links to Maxi fuses.
On my 1976 I relocated the Crank and cab-power wire from the starter to a remote starter contactor next to the RH battery. I still used a fusible link to connect the cab-power wire on a power distribution stud to the battery stud on the contactor. The starter only has one 2ga cable from the contactor to the starter along the oil pan and rail. I have a 14ga jumper wire between the BAT and S terminals on the starter. As soon as there's Juice in the 2ga cable the starter spins. I did use two Bosch glow plug fuses and holders from 1978-1995 VW diesels for the glow plugs... one for each bank.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Thanks guyz ! I'll probably do back to the fusible links after reading the posts in the search section and your thoughtful comments !
