Old 02-10-2016, 01:01 AM   #1
suburban99
suburban99's Avatar
275 60 R15 rear tire question
Put some 275 60 15's on 8" rally rims on the back of my '62 today. Rear end is a GM 10 bolt with 5 on 5 bolt pattern. The edges of the tires contact the inner lip of the box so I had to slightly bend it up inside. Has anyone ever rolled this edge? Or does it have to be trimmed off?
suburban99 is offline   Reply With Quote
Old 02-10-2016, 01:26 AM   #2
Captainfab
60-66 Nut
Re: 275 60 R15 rear tire question
I would leave the rolled edge. That is better than having a sharp edge to cut your tire if things move sideways a little.
Old 02-10-2016, 09:33 PM   #3
ChrisDollins
ChrisDollins's Avatar
Yea rolled is usually the way everyone goes. There's a guy over on ls1tech that rents out a fender roller.
Chris
ChrisDollins is offline   Reply With Quote
Old 02-11-2016, 11:58 AM   #4
PGSigns
PGSigns's Avatar
If it is to close you may have issues when turning or going into driveways as the rear rolls. If you cant get your finger between the tire and the truck good chance it will rub.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-11-2016, 05:47 PM   #5
forestb
forestb's Avatar
You can roll the lip but be careful. I applied a little to much pressure on mine and the fender buckled a little.
forestb is offline   Reply With Quote
