Old 02-10-2016, 01:55 PM   #1
C/10 King
C/10 King's Avatar
Any pic's of 295/50/15 on a 8.5 wheel???
Thinking of running a 295/50/15 on a 8.5 wheel in the rear of my 66', just wondering of any clearance/rubbing issues I might have, and yes the truck will be lowered.... a lot!
Thanks in advance!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 02-10-2016, 04:11 PM   #2
ultrahd4me
ultrahd4me's Avatar
Re: Any pic's of 295/50/15 on a 8.5 wheel???
I wont say you can't, but it will be a ***** for sure. I ran a 255/70/15 on a 15x8 wheel with an adjustable tract bar and 5" rear drop spring. I had to undo the bar and use a ratchet strap to pull the rear end in each direction to get the wheels on. I think maybe a 3-4" drop spring with a lowering block may allow more room to put the wheels on.
ultrahd4me is offline   Reply With Quote
Old 02-10-2016, 04:56 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
I have 275/60/15s on my truck and the 295/50 is not even an inch wider. I don't see any problems and mine are mounted on 8" wheels. Here is the Tire Calculator on Americas tire. http://www.americastire.com/dtcs/infoTireMath.do
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-10-2016, 06:38 PM   #4
steven03
I have 275/60/15s on a 10 inch wheels in the back and they are pretty close to rubbing but haven't had a problem yet. I would think as long as you roll your fenders you will be fine. If they do rub it shouldn't be by much
steven03 is offline   Reply With Quote
Old 02-10-2016, 06:39 PM   #5
chevyrestoguy
chevyrestoguy's Avatar
A 295/50-15 is only 26.6" tall. That's a really short tire for a rear, in my opinion. It will look tiny in the wheel opening, even if the truck is lowered. If you're going for a hot rod look, take a look at a 275/60-15 (28" tall) or a 255/70-15 (29" tall). Those two tires are a lot cheaper than a 295, also.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-10-2016, 10:24 PM   #6
The 275/60 15 on 8" fill my wheel wells up. I don't think anything else wider wheels or tires would fit.
Old 02-11-2016, 10:04 AM   #7
60-66
60-66's Avatar
I had 295 50 15s on this truck but on 10 inch rims. Had to widen the tub. Offset kept it off the wheel lip.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-11-2016, 08:22 PM   #8
C/10 King
C/10 King's Avatar
Thanks for all the input guys, I have the 6 lug 8.5 new wheels ready go and I have nice 245/60 and 295/50 tires mounted on different size wheels, I was just wondering if I'd be wasting my time/money try to remount the tires on the new wheels if its not going to work.
C/10 Rene
1971 Short Fleet
Old 02-12-2016, 06:58 PM   #9
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
I would do 245/50/r15 shorter and wider
Sick5 is offline   Reply With Quote
