Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 02-10-2016, 09:53 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
WIW: NOS 73-87 dash bezel
Not sure exactly what years this was used and it does have a couple of imperfections in pic 2. The aluminum has a bubble in the corner and a spot of some sort up higher. If this is used, it wasn't for long.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-11-2016, 02:00 AM   #2
UKNOWME
UKNOWME's Avatar
Re: WIW: NOS 73-87 dash bezel
Well believe it or not the "if this is used" comment makes a big difference to some. If the holes look like they have had screws installed than I would say the value is approx 1/3 less at least. With the imperfections I think it's a 200-250 piece if no signs of previous use. The original box definitely helps too.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 02-11-2016, 06:56 PM   #3
too much stuff
Roadtrip!
Thanks, I see no signs of use, I just don't want someone thinking this is a showpiece. It is a very nice part. I believe it is nos and just not taken care of properly. What years was this used?
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 02-11-2016, 07:19 PM   #4
UKNOWME
UKNOWME's Avatar
Looks like 84-87. Probably 88-91 suburban too
1964 Chevy c10
Old 02-11-2016, 08:05 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Good thread on dash bezel differences:
http://67-72chevytrucks.com/vboard/s...d.php?t=660034
QUOTE:
Yes, they can be grouped into 73-74, 75-77, 78-80, 81-83, 84-88.
73-74 bezels have a raised area surrounding the headlight knob hole and a fairly narrow hole for the wiper switch.
75-77 bezels have a larger hole for the headlight knob without the surrounding raised area. And a wider rectangular hole for the wiper switch.
78-80 bezels have some styling / appearance differences but I believe they are otherwise interchangeable with the 75-77 bezels as long as you use the corresponding lower steering column cover piece.
81-83 bezels have more of a squared off shape to the upper corners to match the shape of the dash pad.
84-87 (and 88 R/V series) bezels no longer have a rectangular hole for the wiper switch since it's on the column for these years. And the round hole for the headlight switch is moved up a little bit higher as compared to earlier years.
I believe the 89-91 R/V series bezels are very similar to the 84-88 bezels with the only difference being the radio opening.
Keith
Convert to disc brakes.
Old 02-12-2016, 12:19 AM   #6
too much stuff
Roadtrip!
Thanks for the info guys.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
