TH400 Rebuild Advice
Hi all,
I need to rebuild my Turbo 400 to handle up to 600HP to suit a new motor The trans seems stock. I have upgraded the torque converter only at this stage. Before I approach some trans rebuilders I want to get an idea of the parts upgrades I need to strengthen it so I can get value for money. I want to keep it manual/automatic setup. I plan to remove the trans myself and take to the shop. Im just a bit confused with the terminology... corvette servos, direct drums, 34 element sprags, shift kits etc Thanks for any advice |
Re: TH400 Rebuild Advice
I'd put this in the drive-train section. Clinebarger and others would steer you in the right direction.
A stock TH400 will handle everything an LS6 Chevelle can throw at it, so you'd figure a stock rebuild would be plenty for most of our trucks!
Be very clear what you want for a drive experience. If you stick a Stage III shift kit in it you're going to hate it (or love it) every time it kicks you in the spleen on a 1->2 upshift for no good reason. For classic trucks I like them nice and stock, but if yours is a performance build, that's different. Just don't make the mistake I just made and am now in the process of fixing: a drag race transmission in a classic pickup.
#4 | |
install 4L80 Direct drum w/34 element sprag install TH400 rebuild kit dual feed oil to the direct clutches Increase separator holes & fit Trans-go Stage 2 Shift kit Block the 2-3 accumulator He said I would be nuts. and I wouldn't enjoy the ride, all I needed was the 34 element sprag and a standard rebuild. |
![]() Join Date: Jul 2013
Put TOP-SHELF parts in it and the upgraded sprag. TH400s are incredibly strong. If you what the best advice call B&M. Those guys will shoot straight with you on your needs. Plus they are the experts on 400s. Every one else learned from B&Ms R&D work in the 1970s.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#6 | |
They should stick to selling Shifters, Coolers, & Governor kits, NOTHING else! |
#7 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
