Old 02-11-2016, 12:08 AM   #1
_AJ_
54 Duramax build
I'm about done with my 54 so I thought Id share with everybody my progress on this thing. I started looking for a 47-54 truck about a year ago with intentions of doing an LS swap and taking it on the 2016 Hot Rod Power Tour. The plan got a little off track but it'll still be on the power tour come this June. I found this one locally (west texas) and its been a west texas truck its entire life so rust was almost none, cab corners, floor pans, all in great shape. Here it is the day I drug it home
I immediately started tearing the factory drivetrain out
In the middle of planning the LS swap an 07 LBZ Duramax/ Allison pullout popped up on CL locally for a price that I couldn't pass up. So I snagged it with no idea if it could be made to fit. But I figured it was worth a shot.
I got it tore down the the frame
I called Heidts and talked to them about the added weight of the diesel drivetrain and ended up ordering the MII front and 4 link rear setup from them.
I boxed the frame while I had everything off.
Then it was time to see if the duramax could be made to fit.
Got the cab on and started test fitting inner fenders, radiator, etc.
I had to trim the drivers side inner fender to make room for the power steering pump pulley, but other than that it fit nice and snug everywhere, everything is almost touching everything else, but that's ok. I obviously had to cut the cab to make room for the Allison
The outside will be left as is, I love the Patina on this truck but I wanted the interior nice so I got started on that.
So the truck likes this currently
It starts and runs, I've driven it around the block a few times. Gotta get the windshield put in and then I'll venture off to further parts of town to work out any bugs that might pop up. It seems this is sure an abbreviated version of how the truck got to where it is but hopefully its a good shortened version, lol.
_AJ_ is offline   Reply With Quote
Old 02-11-2016, 02:15 AM   #2
Advanced Design
Advanced Design's Avatar
Re: 54 Duramax build
Welcome, and wow! That was a short summary. You have a very cool truck and hopefully you can make HRPT this year.
Advanced Design is offline   Reply With Quote
Old 02-11-2016, 02:43 AM   #3
T_Raven
T_Raven's Avatar
Awesome
My projects
53 GMC, 54 GMC, 67 GMC, 01 GMC DMAX
67, 68, 69, 72 Firebirds, 79 TA, 68 Camaro, 68 Mustang
T_Raven is offline   Reply With Quote
Old 02-11-2016, 12:42 PM   #4
_AJ_
Thanks guys, I feel like I could do an entire thread on everything from the wiring to the steering but figured Id leave all those details out. I've got hundreds of pictures of just about every step of the way but didn't feel the need to bore everybody with all that. Most of you guys have done all that already and probably did a better job than I did.
This thing will make the HRPT for sure, I need to order gauges and the vintage air setup and then it'll be ready. The only concern I have is about the radiator being a bit to small, but time will tell on that, if it is our Texas heat will bring that issue up for sure.
Old 02-11-2016, 01:19 PM   #5
Clay54
Nice project AJ. I have a '54 and a duramax but I won't be putting them together. When you get the windshield in and hit I20, be careful the backend don't try to come around to the front so maybe you better keep several hundred pounds of sand in the bed to keep it straight. Again, nice project. Clay
Clay54 is offline   Reply With Quote
Old 02-11-2016, 10:45 PM   #6
Advanced Design
AJ, wouldn't be boring at all. Even if any of has "done that" before, we can learn a different and often better way. Besides, looking over a build sure beats watching TV!
Old 02-11-2016, 11:53 PM   #7
Coach529
Coach529's Avatar
Awesome looking truck!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-12-2016, 06:13 AM   #8
Nev68
Nev68's Avatar
Cool project.
I like the details so would be interested in any further information you care to post.
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 02-12-2016, 11:56 AM   #9
_AJ_
Well the first major hurdle that almost sidelined the entire project was the fact that this motor and trans came out of a 4wd truck, so the trans needed to be converted from 4wd to 2wd, doesn't sound to bad just typing it out. I did some research on the duramax forums, didn't find a lot, but enough to jump in and try to tackle it, I found out quickly I was probably in over my head, on top of the known tailhousing section and output shaft there was reluctor rings and spacers and snap rings that all their own special place. I believe I finally got it all together correctly, it does seem to shift just fine but I worry about that still.
In an effort to give this radiator its best shot at keeping this thing cool I wanted to keep as much heat away from in front of it as I could, so I did a remote mount trans cooler under the bed with its own fan and used -10 hose to plumb it all up.
Old 02-12-2016, 12:42 PM   #10
_AJ_
Here's a few pics of kinda how the motor sits in there, these were taken during mock up obviously but that's exactly how it ended up sitting. The downpipe went on the turbo just fine with enough room to slide atleast one piece of paper between it and the cab, lol. The duramax from the factory has a huge fan/fan clutch setup, well there was no way that was gonna fit, but it looks like the fan clutch plays a role in holding on the water pump pulley when its installed, so I took the plasma cutter and hacked up the fan clutch just to get the snout off of it so I could screw it back onto the pulley and hold that thing in place. You can kinda see it in one of the pics I posted earlier, its ofcourse centered up with the electric fan motor perfectly and wouldn't allow the radiator/fan to be installed so I had move the electric fan up and over on the shroud to make that all fit.
Old 02-12-2016, 12:59 PM   #11
_AJ_
If anybody is curious what a duramax standalone harness looks like, here it is, 7 keyed hots and 4 constant hots. It was surprising how simple it was really to wire up. All I can compare it to was a few LS swaps, but id say it was easier in terms of wiring than LS stuff.
Old 02-12-2016, 01:09 PM   #12
_AJ_
Anybody ever seen one of these? I found it under the seat. I'm not sure if you will be able to read the small print but its basically a tire inflator, you unscrew a spark plug and screw this thing into the spark plug hole and use the motor to air up your tire! Why do we not have stuff like this still?!?
Old 02-12-2016, 01:17 PM   #13
lower50's
lower50's's Avatar
Fantastic job. Knowing how I put my diesel in my '52 I would love to hear and see more details. Heck What else are you going to do with the hundreds of pictures you took?!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-12-2016, 01:20 PM   #14
lower50's
lower50's's Avatar
[QUOTE=_AJ_;7483491]Anybody ever seen one of these? I found it under the seat. I'm not sure if you will be able to read the small print but its basically a tire inflator, you unscrew a spark plug and screw this thing into the spark plug hole and use the motor to air up your tire! Why do we not have stuff like this still?!?
We don't use this kind of thing any more because most ppl don't even know where there spark plugs are or look like.
1951 MG TD
Old 02-12-2016, 01:31 PM   #15
_AJ_
I've read through your build thread, you've done an awesome job man. That's gonna be a sweet 52 when its all said and done.
Old 02-13-2016, 06:19 PM   #16
FarmerSid
FarmerSid's Avatar
Too cool!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-13-2016, 11:13 PM   #17
84blaze
Cool build. I'm very interested in thee diesel swaps,
84blaze is offline   Reply With Quote
Old 02-13-2016, 11:26 PM   #18
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Great build.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 03-09-2016, 09:38 AM   #19
Firstgenfan
What did you use for the trans tunnel?
Firstgenfan is offline   Reply With Quote
Old 03-09-2016, 10:22 AM   #20
_AJ_
http://m.ebay.com/itm/Hot-Rat-Street...134?nav=SEARCH
I used this one, I took the back part of the tunnel and cut it off, then used that part to finish the front against the firewall. Worked out great for my truck. I mounted my shifter on top of it and it's plenty sturdy.
Old 03-10-2016, 01:33 AM   #21
whitedog76
Great work. Love that beefy trans crossmember. Should keep frame flex to a minimum with all the added torque.
whitedog76 is offline   Reply With Quote
Old 04-10-2016, 10:47 PM   #22
_AJ_
Well I finally got enough bugs worked out that I decided to hit up the Lone Star Roundup in Austin, Texas. It's about a 5 hour drive from where I live. The wife and I left out Thursday with a group from here and headed for Austin.
Didn't have any issues getting there. I stayed with my brother who lives in the area, checked over a few things Thursday evening, all seemed well so we hung out at the show Friday and Saturday.
Had a great time at the show, saw more cool cars/ trucks than you could count and then came home home this morning. Took a few pics on the route home. All in all we drove 940 trouble free miles.
Old 04-11-2016, 07:48 AM   #23
lower50's
lower50's's Avatar
Wow congrats on the trip. You must be so happy.
1951 MG TD
Old 04-11-2016, 02:02 PM   #24
II_Slow
II_Slow's Avatar
I'll see you on the Power Tour, assuming I finish mine. Your Dirtymax install fits a lot better than my 12-V Cummins! I stayed with a heavy frame and suspension (1999 Ram 2500), and I'm doing a lot of spit and polish on mine, and piling on a lot of options so all of that is slowing my down but I'm putting in the hours to finish by HRPT.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 04-11-2016, 09:51 PM   #25
pigpin
Super cool.
The fleet:
2014 Ram 1500 Express, ya its a Hemi
2009 Jeep Liberty Sport- the wife's ride
2000 Chevy C3500- the work horse
1972 Plymouth Custom Suburban Wagon 5.7 Hemi swap
1951 Chevy 3100- project pigpen
pigpin is offline   Reply With Quote
