![]() Join Date: Oct 2012
87 cab on 78 frame
I have a 78 chevy 4x4 stepside.. the cab is shot.. traded a 396 for a wrecked 87 with a very good cab and doors.. i need too know what is all involved in switching cabs. what to keep the 78 fenders / hood , i like this style better.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: 87 cab on 78 frame
it bolts up use the body bushings that go with the frame
Thats it? Been reading that some people say the doors wont line up with the older fenders. true not true..i know about the wiper studs ..
I have 86 doors on my 74. Never did the front end swap but from what I read it's easier to put a 73-80 front end on a 81-87 cab than vice versa.
Sweet ,Thank you for that info
All the doors will work its the front clip ull have issues with. Its the hood hinges and cowl/wipers that are different. The older cowl is on the hood that hide the wipers,the newer cab has the cowl attached with the wipers exposed. Heard it's a lot easier to put the later clip on the earlier cab than it is the other way.....but it can be done with some modification
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
I used an '85 2wd cab on my '77 K10. I had all ready replaced the ft. fenders & doors(for a '77) it all goes together with no problem at all. You will have the 2-hood hinge "slots" in the cowl but that area is open anyway. Use the 4x4 cab mounts, if the replacement cab is 2wd you may have to change the trans tunnel or add a 1" body lift to clear the transfer-case.
John Stevens, ASE master auto tech., ASE master autobody tech. I-car platinum certified '70 Chevy SWB pick up '77 Chevy SWB 4X4 PU 2 '70 Buick GS Stage-1 4-spds |
Thank you. Both trucks are 4x4's so thats covered.. but is still good info for the next guy who needs to do this.
| Bookmarks |
