Old 02-12-2016, 05:50 PM   #1
Edahall
Headlight bulbs keep burning out
I've got a 1990 Suburban with those small quad headlights and the bulbs burn out in very short order. The headlights are Hella European exports and use 55/60W H4 bulbs. So far, it has always been the drivers side low beam that burns out and it only burns out in the summer months when it's hot.
I'm thinking that it may be a combination of too much heat in such a small headlight enclosure and the shock from the 3/4 ton 4x4 suspension that's burning these bulbs out prematurely. The headlights are relayed so there is full juice getting to them.
Is there a bulb out there that will last longer under these circumstances? HID? LED?
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 02-13-2016, 11:57 AM   #2
Edahall
Re: Headlight bulbs keep burning out
Does anyone here any experience with running a Cree LED bulb in a headlight housing that takes a H4 bulb? These bulbs have a much longer life expectancy compared to halogen. They also put out more light lumens but the question if they will put the light in the correct place.
http://www.ebay.com/itm/8000LM-80W-H...VWvnVO&vxp=mtr
Old 02-14-2016, 03:33 AM   #3
andrewmp6
Check your grounds and make sure the headlight don't have a short also.
andrewmp6 is offline   Reply With Quote
