Old 02-12-2016, 10:03 PM   #1
suburban99
suburban99's Avatar
How low is too low?
Hey all, this is the first 2wd truck I have owned...am I too low for normal driving?
I still have to install the windshield so I have not driven it too far yet. Just far enough to test the engine and tranny...
Maybe someone with more experience can give me a measurement from ground to the control arms on their street driven truck? Truck has 2-1/2 drop spindles and 1-1/2 coils cut in the front. 5" drop coils in the rear I think.
suburban99 is offline   Reply With Quote
Old 02-12-2016, 10:43 PM   #2
TopFuel1966
TopFuel1966's Avatar
Re: How low is too low?
Let the air out of all the tires and see if anything bottoms out.
TopFuel1966 is offline   Reply With Quote
Old 02-13-2016, 12:21 AM   #3
Slow Build
Slow Build's Avatar
What size tires are you running? Personally I like a 28" tall tire (275/60/15). It fills my wheel well and keeps the crossmember and control arms a little higher off the road.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 02-13-2016, 12:33 AM   #4
suburban99
suburban99's Avatar
255 60 15 fronts and 275 60 15 rear
Old 02-13-2016, 01:43 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm around 4.5/6 dropped I run a 235/70/15 as a "I can find this cheap" tire, but my actual "ride height" is measured on a 235/60/15 front, and I run a chubby 325/50/15 rear.
@full weight on crap Nitro Drop shocks, I can scrape the skidplate hitting a bridge at 65 (on the rebound actually)
lost about 35lbs off the front, switched to Qa1s, haven't bottomed out since.
Good shocks and an aftermarket bumpstop will let you ride as low as you want.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-13-2016, 12:40 PM   #6
BFoley
BFoley's Avatar
I don't think you are to low. Definitely low enough to be aware of drive entrance elevations and the like. Good looking stance and truck.
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 02-13-2016, 05:42 PM   #7
wjjeeper
wjjeeper's Avatar
My control arms are that low.
Drop your rear and the truck is on point.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 02-13-2016, 06:55 PM   #8
vince1
I thought my 68 short box looked about right after loading it with sand and the guy at the scales whips his window open and yells, "1.8 ton!".
vince1 is offline   Reply With Quote
Old 02-13-2016, 11:07 PM   #9
vince1
I shouldn't comment from the point of view of always looking at them as a work truck. On the other hand I saw one here in the casino lowered and all done up and it sure was a work of art.
I'd pick up the front an inch or two rather than lower it more in the back but this is from an obviously biased opinion.
Old 02-14-2016, 12:40 AM   #10
vin63
It's Better With Nitro
vin63's Avatar
This is mine at full drop. I can still drive it if I lose air to my air springs, but I normally drive it with enough air pressure that raises the chassis a couple more inches than this:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-14-2016, 12:54 AM   #11
BLUIDVL
BLUIDVL's Avatar
Hey there neighbour....nah, never too low. Truck looks good. Just stay away from entering the Petro Can on 1st ave. I've been high centered....haha.
BLUIDVL is offline   Reply With Quote
Old 02-15-2016, 01:01 AM   #12
suburban99
suburban99's Avatar
Yeah know that station well...all my trucks to date have been 4x4...this lowered stuff is new to me LOL..
Old 02-15-2016, 08:03 AM   #13
I have to be careful with mine (4.5/6 drop) 245/60 front, 275/60 rear. Dips will cause me to bottom out the rear at times and since I do drive gravel and dirt roads , I have to go slow so I don't scrap bottom. I love the looks of my truck, but if I ever redid it, I think I wouldn't go as low. I just like driving mine, everywhere, and sometimes it is more of a pain to have the lowered truck than not..
Old 02-16-2016, 01:16 PM   #14
theastronaut
theastronaut's Avatar
You're not too low...
It's almost too low when you haul all your buddies around and it's knocking reflectors off the road.
theastronaut is offline   Reply With Quote
