Its Magically Delicious
still trying to fix heater
ok pulled the glove box to get to the resisitor and heater switch ....removed both and they both look look the springs are fine and .... on the heater harness there is a brown (ground) wire that i traced back to a bundle by my instrument panel .... where does this ground end so ica n check it ......
does the fan switch have a bushing to keep it from falling off ??? im sick of this and i wanna get to the bottom of it before hell freezes over in Oregon
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
This looks like a reply but I couldn't find the original message. Are you trying to fix an air flow
problem, or just having cold air blow? If it is just cold air, make sure you don't have a closed valve in the heater line going to the core. Just a thought.
'69 C/10 Short Wide 350/400/AC/Tilt/Tach |
turns out i need a fuse in both the air cond slot and 1 in the heater fan slot .... i removed the air on becuase i figured it was unneeded.... I CAN CONTROL THE FAN FROM THE CAB NOW !!!! :p .... plus i got a higher powered air cab heater fan .... im still gonna replace the fran switch when it gets here ..... the fan doesn't start moving til the slider is over halfway over ...is this common ..i also have resisitor and a new heater harness too .....
anyone know a good place to get air ducting ...2.5 inch for the defroster .... i'll check lowe's and see just thought i'd update peace ![]()
Firefighter
On your switch, is there a plastic bushing on it where it attaches to the lever for the fan? If not then I would say that is the problem.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
i didnt notice a bushing when i took off the switch to inspect it ...i hope my new one comes with a bushing....
Firefighter
Then I would say that is why your switch doesn't work until halfway across the panel!! Bad part I don't think that the new switch will come with a bushing, but I know that the heater rebuild kit does. You might be able to ask one of the parts dealers or someone on the board for just the bushing.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() Last edited by BLACK AND BLUE 67-72; 09-29-2003 at 09:49 PM. |
ok ... does anyone have a pic of that bushing ...becuase it sounds very easy to make .... im crafty like that ...at least i think i am
a pic will help me out alot thanks ![]()
Firefighter
Hopefully this will show the pic. See the white plastic bushing? Thats your guy! I'm sorry about not finding a better one with a more close up pic but this is all I could find maybe this will give you a rough idea.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() Last edited by BLACK AND BLUE 67-72; 09-30-2003 at 12:58 PM. |
im guessin that little white one is the booger
Firefighter
Yep, That's it!!
it slides right on the pin of the fan switch lever right ??
i bet a Gm dealership either wont have it or that little bushing will be 10 bucks !!!! i had to get my fan aftermarket becuase GM discontinued the fan
Firefighter
Yeah, it slides over the pin on the switch and then into the lever. You might try GMC Paul or WES, or MOTHERTRUCKER , and see if you could get just the bushing. Or if you have the money just order the rebuild kit. I got one for mine, I really like it unbreakable steel levers to do away with the pot metal ones!!
#13 |
Half a bubble off!
Those places, Chevy Duty, LMC, etc. Also get your duct hose through them, I doubt you would find it at Lowe's. Your local parts places should either stock it or be able to get it quickly also.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
#14 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I have the heater duct hoses in stock along with the bushing that you need. Email me if you are interested. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#15 |
how much for just the bushing wes.... i was able to score some air duct already
