Old 02-13-2016, 12:32 PM   #1
Nima
Blue 67
C20 and C10 Spring rates
Hi:
Are C10 springs and shocks softer than C20s? If yes, are they interchangeable? I have been reading a lot as to how to soften my 67 C20 without going through major expense. I read a lot about bags but since the springs on my truck seems to be stock ones, I thought changing them to a softer rating spring/shocks may be a good first step. My truck is stock height with trailing arm, spring, shock and leaf springs on the back. I also didn't want to swap the axles to C10 since I have already have 4 disc brakes and I kind of like my 8 lug wheels. My truck is not a work truck really.
Thanks,
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 02-13-2016, 03:29 PM   #2
SS Tim
SS Tim's Avatar
Re: C20 and C10 Spring rates
67 coil specs.
SS Tim is offline   Reply With Quote
Old 02-13-2016, 10:20 PM   #3
Nima
Blue 67
Thank you.
Based on what I read, please correct me if I am wrong, the front standard shocks and springs are the same in C10 and 20s. However,, the rear is different which make sense since C10 is 1/2 ton and C20 is 3/4 ton. But are theses slight changes is rear shock and spring travel and diameter sizes significant enough to prevent them from being interchangeable?
