Old 02-13-2016, 01:36 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Brake Booster.com
Has anyone had their original brake booster, master cylinder and proportioning valve redone by theis guy.
http://brakeboosters.com/default.htm
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Already Gone is online now   Reply With Quote
Old 02-13-2016, 02:52 PM   #2
davepl
davepl's Avatar
Re: Brake Booster.com
I had mine done by him and have only good things to say. Because I was in a rush he was even able to find a core with the right stampings and codes to exactly match my truck, which is important, because we have brackets and stuff that require longer studs on the master, and the parts-store unit didn't even allow me to bolt up the master.
He was good with email, quick response. Price wasn't that much worse than a replacement, but the quality is hugely different (I won't bother posting photos of the ugly grey painted one I got from Schucks first).
Make sure you get it polished. It's extra, but they are ALL pitted unless and until properly polished out, and that takes time (I think he sends it out).
Picture of mine is below - ignore the lid on the MC, that's just rattle-can, but the finish on the booster is nice and correct.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-13-2016, 03:01 PM   #3
Already Gone
Thanks for the info. I was surfing for Brake Booster info and came across his website. Sitting at a light my brake pedal starts sinking so its time for brake redo. I was thinking of getting one of those 8/9 inch master /booster combos but my wheels started turning when I saw this website. The pic is what is on my truck now which is the original untouched master/booster.
Old 02-14-2016, 10:16 PM   #4
BCOWANWHEELS
sure seems like a lot of $ for gold plating
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 02-15-2016, 12:28 AM   #5
72 Copper C-10
72 Copper C-10's Avatar
I talked to him about rebuilding mine and, he seems like a very knowledgeable guy, and you cant beat his warranty. when the time comes, i will be sending mine to him.
72 Copper C-10 is offline   Reply With Quote
Old 02-15-2016, 02:39 PM   #6
davepl
davepl's Avatar
It ain't gold. What do you normally pay for Zinc Dichromate vs. what he's charging? Or do you just think that process in general is expensive (ie: not that he's more expensive than others)?
Just FYI in my original post I said "longer studs on the master" but I meant "longer studs on the booster", but it's too late to edit it now...
Old 02-15-2016, 03:18 PM   #7
TexasLS1
TexasLS1's Avatar
I'm having the same issue and was getting ready to drop the cash on a new MC/Booster setup, but had not heard of this website. My truck is a '72 - so am I correct in thinking that he can rebuild my MC and Booster, but I'll need to source a new Prop Valve? Do you guys recommend this route over swapping to a CPP MC/Booster set?
Another question I've been wondering - are guys using a special paint or coating on the MC to prevent rusting? Is one of the coatings on the BrakeBooster.com website going to be more resistant to rust and fluid?
TexasLS1 is offline   Reply With Quote
