Old 02-13-2016, 09:32 PM   #1
boraxman
Keepin an eye out
boraxman's Avatar
Couple Steering Column Wiring Questions...
Hi All, going to a tilt and I had this middle piece between truck and column plugs (1st pic)
Now I have the 2 horseshoe plugs (2nd pic truck end on top) but they dont plug tight to each other and the colors are off on some of the wires..Do I need another middle piece?
Lastly do these need to be connected to start the engine?
Thanks in advance...
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 02-14-2016, 12:44 AM   #2
elkniks
elkniks's Avatar
Re: Couple Steering Column Wiring Questions...
I have factory tilt and mine plugs in with the curved connector. It will run just fine not connected, only controls turn signal, hazards, horn.
elkniks is offline   Reply With Quote
Old 02-14-2016, 01:31 PM   #3
snipescastle2
snipescastle2's Avatar
Talking Re: Couple Steering Column Wiring Questions...
Take a few zip ties and tie them tightly together, that will hold them.
ditto on what was said about the signal lights/horn/flashers, without these connected, you lose a lot of important things.....
Ben
snipescastle2 is offline   Reply With Quote
