02-13-2016, 09:52 PM | #1 |
Master Hater
Quick Clean up 85 c20
Picked this up today for a steal, It was so clean I couldn't pass it up, its a C20 with the C6P Heavy duty Chassis package and is a Silverado Package. 350 th400 interestingly enough this can hold a bigger camper than the dually but just 100 lbs less weight . I went and looked at it and it wouldn't hardly run, y pipe is broken and held together with a tin can and a worm clamp , I managed to drive it home 25 miles at 65-70 mph got it home and tinkered with it to find out its got a big vac leak under the carb adapter , the dist was super loose, it is in sad shape. The ad said it had a rebuilt engine with 1000 miles ,, needless to say when i asked the guy about it he couldn't seem to locate the paperwork ..lol I could see by the 2 inches thick of grease on the block it wasn't rebuilt but did seem to run OK on the highway.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
02-13-2016, 09:55 PM | #2 |
Master Hater
Re: Quick Clean up 85 c20
The Brake controller is so old its plumbed directly to the Master Cly. LOL
02-14-2016, 05:57 PM | #3 |
Master Hater
02-15-2016, 02:43 AM | #4 |
Cool rig. What's the plan?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
02-15-2016, 09:26 AM | #5 |
Master Hater
Not sure yet I think I'm just going to clean it up, redo the interior and drop in a vortec long block with a zz4 cam and rebuild the TH400 or find a 4l80E
02-15-2016, 10:17 PM | #6 |
Master Hater
OK got the exhaust redone today , The Original was broken right after the Y on the Y pipe, They had it wrapped up with muffler putty and tin flashing and worm clamps..lol
I just had em replace it from there back with a flowmaster knockoff Xcelerator Muffler I found a used bolt on tip out in the scrap pile.. so I asked what he wanted for it and He gave it to me for free. Also pushed out some of the damaged rear lower quarter.
02-17-2016, 02:39 PM | #7 |
Master Hater
Took the seat and carpet out yesterday, it was so nasty I couldn't stand riding in it until I get it redone..
Gotta love texas trucks.. Heater core had been leaking for sometime I guess, just sprayed down the carpet to get most of the funk out till I can clean the floor off and coat it and add some dynomat and install new padding and carpet and different seats. I go to school full time so I need to drive it 4 days a week. damn sure smells better .
02-23-2016, 10:12 AM | #8 |
Nice clean truck!
03-06-2016, 09:34 PM | #9 |
Master Hater
Picked up a Pressure washer from Tractor supply and went to town on the bottom , Man this thing is clean, but the 30 year old grease was tough to crack, had to use te 0 Degree tip to blast it loose , and I picked up a 90 LO5 from a g20 van fan to flywheel, so thats going in next week and this mix matched pile of crap 350 is coming out.
03-07-2016, 12:50 AM | #10 |
Right on. LO5 have a mechanical fuel pump? Come with a serpentine setup?
03-07-2016, 08:56 AM | #11 |
Master Hater
From Fan to Flywheel.
03-08-2016, 12:59 AM | #12 |
Member of the longbed union.
Truck looks to be in pretty good shape. Do you know of any other local yards that have c10s besides wrench apart in Belton?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
03-08-2016, 04:48 PM | #13 |
I know the pieces fit
Sweet. There was a nice truck under the crud. Are you planning on dog dish caps or different wheels?
03-09-2016, 05:48 PM | #14 |
Master Hater
Different wheels . Ruff, I,ve only been in the area for little over a year and have yet to visit any junkyards, I know there is a yard a bit down 95 pass little river.
