dual exhuast questions
Did 67-72 come from the factory with dual exhaust?
I'd like to install dual exhaust as original to factory as possible. Who out there sells a stainless steel set-up? Thanks Nick |
![]() Join Date: May 2010
Re: dual exhuast questions
Only the big block trucks came from the factory with dual exhausts.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
If you are going to run original exhaust manifolds I'd recommend getting a set of these NOS exhaust donuts and look the seller is in New Jersey as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=691371
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
Thanks First Owner 69 , Already Gone , looking in on the donuts , Thanks
Nick |
If you are looking for factory looking crush bent pipe, walker has 2.25 tailpipes that are replacement for 82 and up 6.2 diesel trucks . If you have a leaf spring truck they go right on. The 6.2 had factory duals. I have used them on a couple trucks One side is universal for single pipe trucks and like 30$ and other is around 50$.
-Cody |
![]() Join Date: Oct 2015
Just seen you were looking for stainless. Not sure on that
-Cody |
I'm not looking to be 100% stock, I just figured anything close would be easier to install. I'm using stock exhaust manifolds, on my 1967 327. I'm not looking for a modified dual sound. I'm looking for more of a factory duel sound. More like casual car and not a hot rod. If that makes any sense. Thanks guys for your help. Nick
#9 | |
Very quiet actually. The 350 with single exhaust sound was pretty much like any normal sedan or factory exhaust gas truck today. You could hardly hear the exhaust at idle and no rumble under acceleration.
Here are the mufflers I used and I wanted the same sound on my truck as you have described as wanting on your truck and with these mufflers that is what I have.
http://www.dynomax.com/super-turbo-c...ffset-596.html
#12 | |
#13 |
I agree.. "I'd send you a video clip of my truck idling so you could hear the sound but its in storage until at least Mid-April."
#14 |
| Bookmarks |
