Old 02-14-2016, 05:16 PM   #1
implanenuts
High and thanks- 66 C10 and 80 C10
I have been reading and learning from these forums for a while now and thought I should post a hi and thanks for all the great information.
I picked up a 66 C10 a while back after looking for several years. It is fairly straight but has the usual rust. I plan on this being a long term project for me and my two boys. I also found a complete and stock 1980 C10 that I plan on transferring the front suspension, power disk brakes and power steering from, then parting out the rest to help pay for it.
I am planning on swapping in the rear axle to get the 5 lug to match the front and match the track with. I know I will have to add perches and a track bar mount, but that does not worry me. If there are any other negatives on the rear axle swap feel free to chime in.
implanenuts is offline   Reply With Quote
Old 02-14-2016, 05:39 PM   #2
akaupp
Re: High and thanks- 66 C10 and 80 C10
Welcome to the forum, glad to see another in Utah. Truck looks like a good starting point.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
Old 02-14-2016, 06:51 PM   #3
BFoley
BFoley's Avatar
Welcome to the forum. There is a lot of great information and knowledge (excluding myself...) here. Looks like a good project.
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 02-14-2016, 08:09 PM   #4
PGSigns
PGSigns's Avatar
Nice project. I like a wheel with a little more lip showing on the back so doing an axle swap to 5 lug instead of the complete rear allows for about an inch more on the wheel. Captnfab here on the board has the saddles to weld to the other rear. Just use caution when you weld it to keep the heat down. Keeps the ends from pulling and adding caster to the rear.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-14-2016, 08:17 PM   #5
Zane M
Looks like a solid foundation to work with. Congrats.
Zane M is offline   Reply With Quote
Old 02-14-2016, 08:38 PM   #6
Mathew21
Mathew21's Avatar
Welcome looks like a great start.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 02-15-2016, 01:15 AM   #7
Captainfab
60-66 Nut
It sounds like you are heading in the right direction with your project. In addition to what Jimmy said about the width, the gears in each differential should be considered as to which one will suit the use of the truck the best. Both differentials should be 12 bolts.
Old 02-15-2016, 12:36 PM   #8
Figuarus
Figuarus's Avatar
Nice truck! I'm in West Valley, if you need some help, Hit me up!
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 02-15-2016, 01:28 PM   #9
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Welcome, looks like you have a built in pit crew there!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-16-2016, 08:24 PM   #10
implanenuts
Thanks for the pointers. Would not have thought about the axle pulling. I haven't got my mind set on the rear end yet. Need to see if one or the other is limited slip or not. That and the gear ratio will play into it.
My plan is to eventually put and LS into it but for now I want to see if I can get the 250 to run.
Old 02-17-2016, 07:35 AM   #11
PGSigns
PGSigns's Avatar
If they are both 12 bolts you can swap the gears if needed. 99% chance the gear in the 66 is 3.73. On your donor is the SPID decal still in the glove box? If so you may be able to get the gear info off of it. It is not hard to distort a housing, carefull welding helps out. Here is a little thing from Joe Gibbs racing on there axle guy. He bends them for a living with a torch and ice. http://joegibbsracing.com/2011/01/12...-kenny-sapper/
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-17-2016, 11:11 AM   #12
implanenuts
I do have the sticker but I have never really understood how to decode them. Where can you find what the codes mean.
