Old 02-14-2016, 07:41 PM   #1
Longley428
4/6 drop finished!
With everyone's help I have finally finished the hotchkis 4/6 drop with 1" blocks additional in the rear to eliminate an rake. But after its on the ground I was checking everything and the rear end is sitting on the bump stops and has a total of 2- 2 1/2" before it bottoms out on the frame. So I believe I'm going to have to take the 1" blocks out because I'm not at the point I'm ready to notch the frame yet. Tell me what yall think!?
Longley428 is offline   Reply With Quote
Old 02-14-2016, 07:42 PM   #2
Longley428
Re: 4/6 drop finished!
More pictures
Old 02-15-2016, 11:34 PM   #3
Jarwood
Jarwood's Avatar
Mine is about 2-2.5 inches from the bump stops. I trimmed the bump stops about an inch. I only bottom out when I have a few hundred pounds loaded in the bed.
Jarwood is offline   Reply With Quote
Old 02-18-2016, 02:43 PM   #4
Darthbaker
Looks good man, i'm about to do a 4/6 static drop on mine as well. What all did you use?
Darthbaker is offline   Reply With Quote
Old 02-18-2016, 09:29 PM   #5
Jarwood
Jarwood's Avatar
I used CPP 2 inch drop spindles and cut one single round off springs.
The rear I used drop springs and 1 inch blocks. I got it all from CPP. I also put disc brakes on all fours and sway bars on front and back. It handles really good for a 42 yr old truck.
Old 02-19-2016, 08:39 AM   #6
6DoF
6DoF's Avatar
that's a hot lookin truck, i love the look
6DoF is offline   Reply With Quote
Old 02-19-2016, 11:12 AM   #7
indymachinist
Could just be the angles but it looks low in the back now anyway. I think it will look better with the 1" blocks out of the back.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 02-19-2016, 01:20 PM   #8
Jarwood
Jarwood's Avatar
I like the look of the truck sitting right on the tires. Its about 1 inch above the tires now. Thanks. I am building a 400 stroker motor for it now. Just bought FAST fuel injection for it. I hope to have it back together by end of summer.
Here are a few more pics after the drop.
Old 02-19-2016, 01:24 PM   #9
Jarwood
Jarwood's Avatar
My interior. I recently moved the gas tank and and put in a rear mounted Boyd tank. I'm going to rung the filler neck out of the rear side marker light.
