1971 seat cover fit 1969 seat
I am looking at seat cover from bothers trucks. My issue is that it is shown for 1971 to 1972 seat and i have 1969 CST, so I just need to know if they fit.
Thanks for the responses. |
Re: 1971 seat cover fit 1969 seat
There is a guy here go's by the handle Truckseats, i would search his threads.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
![]() Join Date: Nov 2014
Yes the seat cover will fit. You might have to build up the thickness of your seat some, but it will fit. Here's a cover I recently got. It's black with grey and black houndstooth inserts built by Truck World. Great quality.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
![]() Join Date: Oct 2009
I just did exactly the same thing. I found that the bar across the back of the lower frame on my seat was higher than on the 71 frame, which meant that the back edge of the seat cushion cover (the part you sit on) needed to be shortened by about 1 1/2", if I recall.
15 minute mod if you can drive a sewing machine. No change to the foam required, although I did wrap the foam in a couple of thicknesses of batting to fill out the cover. This is better than adding more foam because, since it compresses down to nothing when you sit on it, it does not alter your seating position.
1971 C10 Longbed, 350/TH350 |
Thanks fir the reples!! I was thiking about adding 1/2 to 1 inch high density foam to the top of the bottom foam. All the foam is there and all the springs are good, just wanted to add a little to the old foam.
| Bookmarks |
