Old 09-22-2003, 05:32 PM   #1
anthony_1269
Temperature Gauge?
Just wanted to ask before I dive into this. My temp gauge has not been working for a couple of months. All of a sudden, when I started the truck yesterday, it went crazy....kept on going back and forth, and then stops for a little while and then starts again. Does anyone have an idea of what may be wrong w/it? Is there something specific I need to replace, or should I just get a new temp gauge? Thanks
Joe
1971 Chevy Longbed Fleetside
Chevrolet All The Way!
anthony_1269 is offline   Reply With Quote
Old 09-22-2003, 05:49 PM   #2
J.Lance
Too many is never enough!
temp
Sounds like the wire is shorting out. Check the routing of the wire along the valve cover and block. While it's covered (stock) with a heat sleave, it usually deteriorates over time. More often than not the wire is quite brittle and broken in a few places. If it's an original wire, replace the wire from where it comes out of the firewall gutter harness to the sending unit and see if this solves your problem before you start looking for a new gauge or sending unit.
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 09-22-2003, 11:17 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Probably the wire like said before. Look on your manifold on the drivers side for a melted green wire.
It is grounding out every once ina awhile (like on speed bumps) and evertime it grounds, the guage will peg out.
Old 09-23-2003, 09:02 AM   #4
anthony_1269
Checked it yesterday and it was fine, was getting power and everything. Today I am going to replace the temp sensor on the block to see if that is it.....
Joe
Old 09-23-2003, 12:47 PM   #5
67chevemall
67chevemall's Avatar
Sounds like the wire is grounding out!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 09-23-2003, 01:16 PM   #6
A.P.
Black 72 Chevy
A.P.'s Avatar
Ground the green wire and see if it good to the H and stays there. Or just disconnect it from the temp sensor and see if continues.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
