Old 02-15-2016, 01:41 PM   #1
tommy217xxx
tommy217xxx's Avatar
Hinge rebuild kit options
Hey everyone, I need to rebuild my hinges. I saw a kit at advanced auto by help. I think it was the dorman or something like that. Is this a good option or should I look some where else? What does everyone like?
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 02-15-2016, 02:08 PM   #2
tucsonjwt
Re: Hinge rebuild kit options
If you are referring to hinge pins and bushings, don't get the Dorman kit. Get the OEM GM pins and bushings from a GM dealer or buy online from an OEM vendor. The Dorman pins are too big for the bushings. Search for hinge pins in this forum and you will find the OEM part numbers in a posting I did on this subject.
tucsonjwt is offline   Reply With Quote
Old 02-15-2016, 02:22 PM   #3
tommy217xxx
That's it. Thanks man
TJ
80 Chevy c10 lwb
305/350
Old 02-15-2016, 05:19 PM   #4
tommy217xxx
How many puns and bushings do indeed? 2 pins and 4 bushings per door?
TJ
80 Chevy c10 lwb
305/350
Old 02-16-2016, 02:35 AM   #5
Jrgunn5150
Huh, I have Dorman pins and they fit ok? I mean, I tapped them in with a hammer, but nothing major. My OEM bushing's were plastic and busted.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 02-16-2016, 11:02 AM   #6
tucsonjwt
If you look at the links I listed, you will see that the Dorman pins (with Dorman bushings) did not seat all the way down, regardless of how much I hammered them. The splined top of the shaft would not seat. I tried all of the bushings furnished with the Dorman package. I only saw one Dorman kit at the parts store - maybe you got a different kit. For about the same price you can get OEM GM pins and bushings, so that's what I used. My 83 had brass bushings which were worn out, not plastic.
Old 02-16-2016, 11:10 AM   #7
tucsonjwt
Here is link:
http://67-72chevytrucks.com/vboard/s...ght=hinge+pins
Old 02-16-2016, 04:43 PM   #8
Jrgunn5150
I got mine from Summit Racing, but I wonder if my puns were replaced before... Learn something new everyday lol
J.R.
Old 02-16-2016, 10:14 PM   #9
tucsonjwt
Many people drill out the hinge hole to make the thicker Dorman pins work. I did not care for that idea, since OEM pins and bushings are still available.
Old 02-16-2016, 10:20 PM   #10
Jrgunn5150
I didn't do anything like that, I cut the stock one's, and my nephew pulled them out an tapped new ones in, he's 4 lol. I must have gotten a different part or something,
J.R.
Old 02-16-2016, 10:40 PM   #11
tucsonjwt
Those Michigander 4 year olds are known for their super human strength.
Old 02-16-2016, 10:43 PM   #12
Jrgunn5150
Well I still have two packs, because I wasn't sure if I was getting a pair or one in a box, so I'll see if I can dig them out and get the part number off them, because you're not the first person I've seen say the Dormans didn't fit correctly, but by then I already had installed them lol.
So now I'm curious what's different, about my truck, or my new pins, because with him as my only help, I still had it done in an hour, easy peasy.
J.R.
Old 02-16-2016, 10:51 PM   #13
tommy217xxx
That's true Michigan kids are tough as nails or in this case pins.
TJ
80 Chevy c10 lwb
305/350
Old 02-17-2016, 02:56 PM   #14
tucsonjwt
Most likely the previous owner of your truck drilled out the hinge holes.
GM part numbers are in the link I posted above.
My local dealers were to lazy to look up the part numbers so I bought them online. Some OEM vendors online:
www.oewarehouse.com
www.oehq.com
www.gmpartsdirect.com
www.rockauto.com
www.davesauto.com
Also, once you have the part numbers, always check Amazon and Ebay for OEM parts.
Old 02-17-2016, 03:00 PM   #15
tommy217xxx
Here is the pin and bushing part numbers
20046147 - pins
9721917 - bushing
TJ
80 Chevy c10 lwb
305/350
Old 02-17-2016, 11:06 PM   #16
85/Silverado
85/Silverado's Avatar
I grew up in Rochester Mi. and joined the Marines at 9. Yes we are tough.......
85/Silverado is offline   Reply With Quote
Old 02-19-2016, 11:49 AM   #17
tommy217xxx
I found the pins and bushings at a local gm dealer. Total cost was $31 for everything. I would much rather had real gm parts on my truck.
TJ
80 Chevy c10 lwb
305/350
Old 03-07-2016, 08:46 PM   #18
l79m20
Talking Re: Hinge rebuild kit options
Dorman has supplied GM with OEM fasteners for years and years, I would not hesitate to use a Dorman product, the alternative is usually Chinese!!
l79m20 is offline   Reply With Quote
