Old 09-22-2003, 05:51 PM   #1
WB72
Before and After
WB72's Avatar
Question Lower Ball Joints
Do you need two different forks to remove the ball joints on 71 C10 ball joints?
I have the fork for the upper ball joint. It doesn't fit for the lower. Is there a cheaters way to getting around buying another fork or should I just go and get another fork?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 09-22-2003, 05:54 PM   #2
WB72
Before and After
WB72's Avatar
OOPS.
I have tried to beat it out of the spindle, but it won't budge.
66,000 miles.
Alberta, CANADA
Old 09-22-2003, 06:24 PM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Go to a local parts store and rent a balljoint press. It looks like a big C-clamp. You just set the little cups on the balljoint and tighten it down with a 3/4 end wrench or even an impact socket. Here's a pic of the kit.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 09-22-2003, 06:58 PM   #4
COBALT
COBALT's Avatar
He's talking about the pickle forks.
Yes, you end up having to use two different ones, or at least I had to (3/4 ton '69 C20 w/ drums).
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-22-2003, 08:13 PM   #5
boraxman
Keepin an eye out
boraxman's Avatar
If youre having trouble separating it from the spindle, do this...
1. hook up the upper ball joint getting the nut fully covering the threads.
2. get yourself a bottle jack wedge it between top and bottom a-arms and start jacking it carefully.
3. once you get some good pressure start beating with a 3lb hammer along with using your seperator or anything you can get leverge with. Beat the threads of the lower joint, the spindle and the a-arm.(wont hurt it). Sooner or later it will pop off.
Also keep in mind I used this method without springs installed....good luck!
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
