Old 02-16-2016, 02:28 AM   #1
GM man
GM man's Avatar
In tank fuel pump ideas/suggestions for Ram Jet 350
My original 350 has a little over 450k miles on it and is in need of a long rest. I'm thinking that I'm gonna replace it with the Ram Jet 350. I know GM recommends using an in tank fuel pump, so I need advice on the best way to accomplish that. Is there a tank from another vehicle that would work for this or is there a good way to retro-fit a fuel pump unit in the factory tank?? And,...has anyone seen or heard about anyone using a small fuel cell (like a 5 gallon), mounted in line with the factory tank that could house the fuel pump and serve this purpose??
1972 GMC Jimmy 6.0/4L65
1972 Chevrolet long bed 1/2 ton
GM man is offline   Reply With Quote
Old 02-16-2016, 08:31 AM   #2
1rippen6
Re: In tank fuel pump ideas/suggestions for Ram Jet 350
Check in the LS engine section some people are using a newer fuel injected blazer tank that has the pump in it. Not a direct bolt in but appears to be an easy modification and is like a 31 gallon tank. There maybe an application that the pump will fit but the old tanks don't have baffles and I'm sure someone will correct me if I'm wrong but I think the in tank pumps need baffles.
1rippen6 is offline   Reply With Quote
Old 02-16-2016, 08:40 AM   #3
A1971Blazer
A1971Blazer's Avatar
Here's a thread on it......
http://67-72chevytrucks.com/vboard/s...rban+fuel+tank
A1971Blazer is offline   Reply With Quote
Old 02-17-2016, 12:41 AM   #4
GM man
GM man's Avatar
Thanks guys for the responses.
But, just FYI, I just found this on the aeromotive website today. This looks like an awesome setup where you can keep your factory tank and just modify it for the pump. It also comes with the baffling that it needs. It's a little pricey, but for the convenience and the quality of aeromotive I'm gonna give it some thought. It's: http://aeromotiveinc.com/phantom/
Old 02-17-2016, 02:04 PM   #5
cleszkie
cleszkie's Avatar
I run the Aeromotive Phantom in-tank pump in my aftermarket 40 gallon tank. Pricey yes, but rock solid performance with high quality components, and very easy to install.
cleszkie is offline   Reply With Quote
Old 02-17-2016, 02:51 PM   #6
A1971Blazer
Are you running a returnless configuration? I see a lot of people using a Corvette filter/regulator with a single line fuel rail (LS1) style where the return goes back to the tank directly from the regulator.
Old 02-17-2016, 08:25 PM   #7
cleszkie
cleszkie's Avatar
I run a return style system with a fuel pressure regulator downstream of my fuel injection rails. The fuel goes directly to the tank after it passes through the regulator.
Old 02-18-2016, 10:10 AM   #8
jaros44sr
jaros44sr's Avatar
It would be nice if you use the 2000 era truck fuel pump, has a basket in it so if you run low on fuel, you will have a constant supply. Some of the problems you'll run into is sloshing away from the pick up. I'm using something like it, just had to modify a bit to sit on the bottom of my tank
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
