Old 02-16-2016, 04:45 AM   #1
ben88
Front coil spring Question (to ut / or not to cut)
Hi All:
I will cut straight to the chase, I have a 68 Stepside and i converted the front end to the 73 and up front end using ^8 upper and lower control arms and 73 and up spindles as well as steering linkage. When finished with the conversions my truck was MAGICALLY lower in the front. I then fabbed a 68 GTO posi to fit the rear ($100 from a friend). While doing the rear end conversion I also installed 2 in drop springs.
My question is, Can I cut the coil in the front to lower the truck just enough to where its the same height in the front as it is in the back or perhaps lower. After finishing the rear it seems that the front is Approx 1'' higher. I also was able to get a New set of 275/60/15. I am proud of this because giving the fact that I am getting my degree in Mechanical Engineering it took a while to save up for the tires HAHAA.
I want to lower the front without having a tire clearance issue problem.
Any help is greatly appreciated.
ben88 is offline   Reply With Quote
Old 02-16-2016, 07:36 AM   #2
Elliot949
Elliot949's Avatar
Re: Front coil spring Question (to ut / or not to cut)
Well as inexpensive as front springs are I would suggest that you just order the "drop" size you want... Cutting springs works to a degree but will never seat properly in the spring cup and can have a negative effect on drivability... ECE or CPP sell set for under 100.00 shipped...
Set of 2"
http://www.ebay.com/itm/60-72-CHEVRO...FVFdBK&vxp=mtr
And a set of 3"
http://www.ebay.com/itm/1963-72-Chev...1VeiyJ&vxp=mtr
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 02-16-2016, 04:35 PM   #3
benw88
If I Purchase the 2'' drop springs do you guys think my tires will hit my fenders? Also can i still use stock shocks with those springs ?
benw88 is offline   Reply With Quote
Old 02-16-2016, 08:05 PM   #4
benw88
bump
Old 02-16-2016, 08:13 PM   #5
Elliot949
Elliot949's Avatar
A 275 is awful wide and it is a strong possibility... widest I personally seen is a 255/50...
Old 02-16-2016, 08:18 PM   #6
benw88
The difference in the tire width would be sightly less then 1 in. so less than 1/2 in on each side.
What about the shocks?
File Type: pdf Screen Shot 2016-02-16 at 4.16.27 PM.pdf (147.8 KB, 63 views)
Old 02-16-2016, 08:49 PM   #7
Elliot949
Elliot949's Avatar
Either cutting the spring or by in the 2"spring a good option is again either CPP or Early Classic Enterprises (ECE) short shocks...
Old 02-16-2016, 09:36 PM   #8
Average Joe
Average Joe's Avatar
Cut your existing coils. If you dont like the ride r/r with lowered ones. 1 full coil gives approx 3" drop and 1/2 a coil (in my exp.) will only give 1" drop. It will ride stiffer but so will a lowered spring.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-17-2016, 06:42 AM   #9
BigMike
BigMike's Avatar
I've cut many springs on many different vehicles and found the trucks to be the easiest to do and still fit well. I had 2" coils (CPP) and wanted to go a little lower so I cut 1/2 coil out if them which gave me about an inch or so more drop for about a 5.5" total drop up front (with my 2.5" dropped spindles). I had no seating issues and rode the same as the 2" did, just a a little lower.
They are cheap to buy but if you lack the funds or just want a drop right now, cutting them in a good option. You can start with 1/2 coil, the 1, then 1 1/2, etc... until you get your desired height. Once you find a spot you like you can either just keep it that way or buy a new spring with the drop that equals the amount you cut out of the old spring.
Mine still rode pretty good except I bottomed out many times. I eventually went with bags.
BigMike is offline   Reply With Quote
Old 02-17-2016, 10:25 AM   #10
New_70'C10
New_70'C10's Avatar
I have to agree with most others here and say start out with taking off a half coil to see how it sits and what type of clearance you have with your tires. I'm running 275/50/15 on a 10" rim and even though it's only made it around the block once or twice I don't recall any rubbing issues. The PO got a little carried away with the torch on mine and all four corners are pretty much collapsed but I must say I like the stance of it if I can only recreate it with the proper equipment.
Good luck...and stay in school.
Charles.
1970 SWB CST; 307ci, 200-4R, (Slow Motion)
New_70'C10 is offline   Reply With Quote
Old 02-17-2016, 03:38 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
I am running CPP 3" front. 4" rear drop springs on my 72 swb step (profile pic) with 275 60r15 all around. No rubbing at any time. The wheels on it now are wheel vintiques 15x8. I believe they are 4" backspace. I had the same tires on factory 15x8 truck rallys and the fit was exactly the same, just wanted the poverty cap look.
WIDESIDE72 is offline   Reply With Quote
Old 02-17-2016, 11:18 PM   #12
'68 Newtricks
'68 Newtricks's Avatar
I'll add a question. When you cut, do you cut from the bottom or top of the spring? Seems the top winds a little tighter, so cutting the bottom and letting it seat properly in the LCR would be best, no?
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-18-2016, 10:55 AM   #13
Boog
laying low
Boog's Avatar
Cut off the bottom of front spring only. And do not cut the rear springs.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
