Old 02-16-2016, 10:11 AM   #1
Curt - TN
57 Replacement Frame Options (RR Frames)???
I am on the fence of modifying my stock frame with modern suspension or doing an after market frame. I came across a frame that looks pretty cool from RR Frames and was wondering if anyone has built one with their frame yet? I am trying to find a finished truck with one of their frames so I can see the stance.
It seems pretty cool, they build a frame to accept a complete drop out front and rear from a C4 corvette.
I just did a 56 Corvette with a similar set up from another manufacturer and it rides awesome but they do not make a truck frame,
Any other frames you all have built on?
http://rrframes.com/55-59-chevy-truck-frames/
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 02-16-2016, 10:38 AM   #2
dsraven
Re: 57 Replacement Frame Options (RR Frames)???
with the US dollar being what is it comp[ared to Canadian you might want to check out Canadian hotrods. they make a complete frame with corvette underside. all gm parts for the corvette stuff. it comes ready to drop your truck onto it. fully engineered and boxed with brake lines, fuel lines and battery cables inside the frame. you tell them what you want for engine/trans and they set it all up to accept that. they have a website for you to see how it all looks and what the stance is when completed. I have seen one of their frames up close and they are nice. powder coated as well.
Old 02-16-2016, 10:49 AM   #3
Curt - TN
Thanks, I will check them out.
Curt
Brentwood TN
1957 GMC 100
Old 02-16-2016, 02:36 PM   #4
_Ogre
_Ogre's Avatar
if you can swing the money for an aftermarket frame, that puts you miles ahead of where most of us started
i know ogre spent over a year just on his frame
also check out fatman fab in charlotte nc, they make a good product and shipping would be less than from montana
shop air compressor timer
Old 02-16-2016, 03:02 PM   #5
dsraven
it's called the road hugger chassis. they take original corvette underpinnings, rebuild it all etc, and install. that way you get original gm stuff. all the brackets and frame rails are computer cut and welded on a frame jig. nice and solid.
Old 02-16-2016, 03:06 PM   #6
Highsider
Highsider's Avatar
Seems very few TF owners swap frames, especially compared to AD builders.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 02-16-2016, 03:14 PM   #7
ptc
ptc's Avatar
No offense to anything or anyone Canadian.... but there are enough starving automobile parts dealers and customizers right here in 'Merica that could use your hard earned AMERICAN dollars if you are in the spending mood.... feed OUR economy ..... Just Sayin'
You've got many many choices out there, so shop around and make the best deal with any one of them. Im sure they all will work hard for YOUR Business.
Good luck on your build.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-16-2016, 06:38 PM   #8
crossfire84
crossfire84's Avatar
It's not that hard to do your self, I made my own rear mounts for about $52 of steel.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 02-16-2016, 06:50 PM   #9
Curt - TN
That looks awesome, I have thought about modifying my frame. If I keep the same frame I need to cut it down to a short box also.
Have you figured out ride height yet, will it be standard height or will you be able to drop it?
RR Frames sent this picture of a truck they are building now and the back sits a bit high for my liking and it does not have much downward adjust ability.
Curt
Brentwood TN
1957 GMC 100
Old 02-16-2016, 07:35 PM   #10
67 chevelle
67 chevelle's Avatar
here is a viable option .
http://www.e-zchassisswaps.com/kit.php?category=5
Im looking at a camaro sub this weekend
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
