Old 02-16-2016, 11:35 AM   #1
homeboymi
homeboymi's Avatar
Refinish truck bed wood
I bought this truck with a wooden bed that is shedding the clear coat finish. How much of the bed do I need to disassemble to sand and refinish the wood?
All of the bolts and stainless strips are like new. Someone just did a lousy job of staining and clear coating the wood during restoration. It used to look like the orange spots you see before it turned gray.Name:  IMG_0606.jpg
homeboymi is offline   Reply With Quote
Old 02-16-2016, 11:45 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Refinish truck bed wood
its not that hard but I would remove it all and refinish it. the pain looks really nice so don't cheap out ( not that you would but)
This is quite common in sunny climates and little or no protection from the sun.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-16-2016, 01:32 PM   #3
homeboymi
homeboymi's Avatar
I've watched utube videos and read numerous posts about refinishing the wood. They all seem to be with the bed off. If I remove all the carriage bolts, take the fender wells out, will the boards slide out? Just trying to get a feel of the work involved to do this project. Thanks
Old 02-16-2016, 01:37 PM   #4
oem4me
Disassembling the whole thing would net the best results, but I suppose it's possible to carefully avoid the strips when sanding off the old finish. It might even work better to remove what left of the old stuff with a scraper.
Done correctly, scraping would leave the wood surface clean, smooth, and ready for a new finish. The down side of doing this with the strips in place is not being able to get into the grooves very well and risking eventual failure starting from those edges.
Also, next time make sure to use a high grade exterior finish which has UV blockers in it.
