NEW 588" Merlin Alum Block BBC w/ ProCharger
588 Cu. In. Supercharged BBC ENGINE Ready to Run
Merlin Alum Block 4.625” Bore Internally Balanced, SCAT Crankshaft 4.375” Stroke, SCAT Rods, Aries Pistons, Total seal Rings, ARP Studs throughout Moroso Alum oil pump, Pan Merlin Alum Intake Manifold, 4150 base flange AFR 350 Magnum Heads Alum. 116cc Chamber Deck height @ 0.00”, Head Gasket .048, Comp Ratio 8.22 Manley titanium Intake Valves, Exhaust Valves, Titanium Retainers Comp Cam HYD Roller Cam Comp Cam HYD Roller Lifters Comp Cam Dual Roller Timing Chain assembly F2 Pro Charger Self Contained, Pulley Setup to produce 18LB Boost Blow off Valve, High Velocity Carb Hat Holley 850cfm Blow Thru, Carb Shop Prepared Includes: Electric Water Pump 50 GPM, MSD Ignition, Carbon Fiber Valve Covers, All Stainless Steel Oil lines, Extra SC Pulleys This is a complete ready to run engine from carb to pan. $36K invested in total build. ASKING $27,500.00 Will prepare for shipping at cost.
My Build: 57 Chevy Pro-Street |
