Old 02-16-2016, 04:35 PM   #1
weldvair@embarqmail.
Smile door hinge pins/bushings
I have been calling local dealers & checking on line but can not find gm door hinge pins for my 1968 c10.
Any ideas on where I can find door hinges/bushing.
Thanks Don
weldvair@embarqmail. is offline   Reply With Quote
Old 02-16-2016, 04:42 PM   #2
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: door hinge pins/bushings
http://www.classicindustries.com/pro...rts/*c57e.html
has the pins and bushings to do ONE door so you would need to order two for the truck
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 02-16-2016, 05:47 PM   #3
rmc70
I tried the pins on my 70 but still had a movement that I did not like. New hinges are the best way to go' At least for me it was.
rmc70 is offline   Reply With Quote
Old 02-16-2016, 10:13 PM   #4
swamp rat
swamp rat's Avatar
Go to the vender page and contact just about any of them.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-16-2016, 10:28 PM   #5
hugger6933
Go to the parts store and look on their HELP boards. Make sure to get the bronze bushing instead of the plastic[yes they make plastic door hinge bushing]
hugger6933 is offline   Reply With Quote
Old 02-16-2016, 10:39 PM   #6
leddzepp
Moderator
leddzepp's Avatar
This ^^^
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-16-2016, 11:29 PM   #7
I reviewed the suggestions but, could not find any thing but reproduction.
Don
Old 02-17-2016, 07:02 AM   #8
Grumpy old man
Grumpy old man's Avatar
I've used a few of these sets with bronze bushings , The price is great and they fit perfect ,The pin is a little longer but you can easily trim it once you have them installed
http://www.manestruckparts.com/store...&Category_ID=7
Grumpy old man is offline   Reply With Quote
Old 02-18-2016, 01:49 AM   #9
swamp rat
swamp rat's Avatar
Even the bronze bushings have some slop unfortunately.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-18-2016, 10:22 AM   #10
WillW23
I make my own bushings out of oil-lite bronze and press them into place, so it has a tight fit, even use a GM door hinge pin as well.
Willie
WillW23 is offline   Reply With Quote
Old 02-18-2016, 11:04 AM   #11
Grumpy old man
if you tried the bronze bushings and you still have hinge movement it's time for a new set .
OR
Old 02-18-2016, 07:56 PM   #12
hugger6933
I agree if you get the right[ correct] bushings, the hinge should be as tight as new or better. I still can't get over the General using plastic there and the most amazing thing, that they lasted. I have rebuilt a set on Wiggy's truck[ current customer frame off] and they are tight as can be.
Old 02-18-2016, 10:47 PM   #13
franken
As mentioned, these are in the (Dorman) help section of any parts store. I seem to recall that the pin diameter is .25" and the kit comes w/ a bunch of bushings of various ODs.
Or: https://www.google.com/search?q=dorm...sAQIVA&dpr=0.9
franken is offline   Reply With Quote
Old 02-19-2016, 01:52 AM   #14
swamp rat
swamp rat's Avatar
OR
I have bought 4 sets of hing pins with bronze bushings from 2 different local vendors off this board, both touted as the rear deal, best you can get, ect. the bronze bushing and pin have slop even brand new, yes way better than the plastic stuff but still have some slop. are they the same as OEM for the slop? I don't know.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-19-2016, 07:16 AM   #15
Grumpy old man
The hinge pin /bushings I bought from Manes I used a 2 lb brass hammer to install the bronze bushings into the hinges using my large anvil vise and then using the same hammer drove the pins in ,There tight so I will be buying a few more sets from them because they worked for me .I'm sure there are many different size bushings being sold ,I buy a lot of parts from Manes because they don't just sell parts for these trucks they use them also .
Old 02-19-2016, 01:21 PM   #16
WillW23
The hinge pins I use are GM, and we turn our own bushings out of oil-lite bronze, on a lathe, to fit even oversize worn holes. Then press them in with a shop press, even replacing the roll pins on the slider hinges. Not a so called kit, when you make your own.
Willie
Old 02-19-2016, 01:30 PM   #17
Grumpy old man
Willie
You do this for a living , what is the cost to rebuild a set of hinges ?
Old 02-19-2016, 01:34 PM   #18
WillW23
I rebuild hood and door hinges for a living, and have been mentioned in a few post on this forum. I doubt the moderators would want me to give pricing on here, or post my website, and rightfully so. Some others have posted it, and you could search for threads there, and then contact me.
Willie
Old 02-19-2016, 06:01 PM   #19
Grumpy old man
Willie
Great , Become a subscribing member and enjoy the site !
Old 12-20-2022, 07:46 PM   #20
MeanGreen72C10
MeanGreen72C10's Avatar
doing a set of hinges myself soon looking into some options.
MeanGreen72C10 is offline   Reply With Quote
Old 12-20-2022, 08:12 PM   #21
Accelo
Accelo's Avatar
"Yes they make plastic door hinge bushing" as they were installed in all the hinges, from the factory.
I have rebuilt my share of hinges. None were loose after rebuilding unless the hole for the bushing was worn oblong. I drill a small divot on the top of each hinge before taking them apart. That way I install the pins correctly, from the top. Easy to mess up how they go together, if not marked.
The most difficult part, of rebuilding, is getting the old pin out.
Even with a press you can bend the hinges ears if not careful. Lots of heat, will typically get out even the most stubborn hinge pin.
Don't forget to replace the hinge stop nylon.
Classicparts is the only vendor I know of for this part.
https://www.classicparts.com/1967-72...UaAgh0EALw_wcB
Accelo is offline   Reply With Quote
