Old 09-22-2003, 06:44 PM   #1
xenocide
Question Battery Gauge
This is the most my battery/amp gauge ever shows; is this normal? This is at idle and it is exactly the same at cruising. I haven't had any problems since I replaced my alternator/voltage regulator 6 months ago or so, but I just wanted to know what everyone else was seeing on their vehicles - if it was similar etc.
I'm also considering adding some extra autometer guages for oil temp, transmission temp, and maybe another. - any suggestions to what other gauges to add? I just like to have a good idea of how things are doing. On my other cars I have a palm pilot with a datalogger program connected to the diagnostic port to view all my timing, knock, temps etc. so I guess I want to be more informed when I'm driving the beast. Thanks in advance!
'72 Chevy Cheyenne Super (402 BB / 3/4 Ton / Hedman Hedders / Air Gap Intake / Street Avenger Carb)
'90 Talon TSi (Turbo / All Wheel Drive / Modded)
'93 Dodge Stealth RT/TT (320 HP / All Wheel Drive and Steering / Wife's car)
xenocide is offline   Reply With Quote
Old 09-22-2003, 06:48 PM   #2
smokekiki
Mike
smokekiki's Avatar
Mine will jump to the 2nd line above the half way mark.After about 2seconds it goes where yours is.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 09-22-2003, 06:53 PM   #3
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
that is where mine is at all the time as well. Only barely moves when some other electrical item is turned on. Haven't had any problems in that area. (wood)knock-knock..
-Ron-
OldSkool71 is offline   Reply With Quote
Old 09-22-2003, 06:59 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is that guage supposed to work??? None of my truck's ever had that guage work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-22-2003, 07:00 PM   #5
xenocide
Cool, then it must be normal. It's just one less thing I have to worry about then.
Old 09-22-2003, 07:57 PM   #6
JimKshortstep4x4
Smile
The amp meters work somewhat. They are an indicator more than they are a gauge. I would check the two fuses to make sure and check the amp output of your alternator. If the battery and charging is good the amp meters will go back to neutral fairly quickly. Also, check for discharge when you pull the lights on without the engine working. It should discharge about 1/2 way.
Jim
Old 09-22-2003, 10:29 PM   #7
palallin
Glad I'm not the only one
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-23-2003, 12:13 AM   #8
Orion 762
If I looked at the schematics right, it looks more like it's setup to read voltage instead of "amps". If it's a voltmeter, then it's just "indicating" the battery voltage. A true "ampmeter" will show the "draw" of charging or discharging current from the battery.
Any ideas on whether I'm right on this??
Orion 762
Orion 762 is offline   Reply With Quote
Old 09-23-2003, 01:59 AM   #9
70short
The amp meter measures the load (accessory draw)across the battery or A shunt. The volt meter is measuring voltage to ground. They look similar in the way they are physically hooked up, But one measures volt the other amps. I hope this made sence.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 09-23-2003, 02:33 AM   #10
BadAssChevy502
Yeh It's Fast
BadAssChevy502's Avatar
Exclamation Bad gauge
Hi,
I'm working on my second truck now and neither one ever worked I have never found out why it didn’t.
I even took one out and placed it in a wire setup where it should work and it still didn't so I gave up on it.
If someone ever figures this out let me know it’s nice when all the gauges works
Is there also a gauge for the blank one on the right hand side of the steering wheel? Or is this a special option.
(I'm sorry if the spelling isn't correct,i'm trying the best I can )
1972 Chevy Pickup longbed 502ci Th400
"IF IT AIN'T BROKE DON'T TRY TO FIX IT"
BadAssChevy502 is offline   Reply With Quote
Old 09-23-2003, 05:43 AM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
I think options for the phantom (#3) position gauge were clock or vacuum (manifold pressure). Both pretty rare.
Old 09-23-2003, 08:31 AM   #12
webhendrix
I had replaced my regulator and then my alternator. My gauge worked and would go past that mark as it was over charging.
(I had probable damaged it trying to figgure out my charging problems. It was the alternator.)
I replaced the regulator again and now it stays where yours is. The over charging problem was fixed with the (2cd) new regulator. (Values stayed in a normal limit).
webhendrix is offline   Reply With Quote
Old 09-23-2003, 12:35 PM   #13
JimKshortstep4x4
Smile
Webhendrix,
Did you check the two 4 amp fuses on either side of the radiator?
I have not seen an amp meter burn up in one of these trucks, although I guess it could be possible. The fuses do very well at protecting the gauge.
Jim
Old 09-23-2003, 12:40 PM   #14
smitty62
smitty62's Avatar
I want to emphasize to you fellows, JimK is right-90% of the time the amp meter problems are due to a blown fuse just where Jim says they are-either side of the radiator.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 09-23-2003, 01:22 PM   #15
A.P.
Black 72 Chevy
A.P.'s Avatar
I replaced my amp meter with a volt meter and it works great. I got the volt meter from Pep Boys.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 09-23-2003, 02:08 PM   #16
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Bad gauge
This gauge pod is for either an air pressure gauge or a vacuum gauge, neither of which were installed on light duty trucks. This makes sense when you factor in that the same bezel and cluster configuration was used on HD trucks 1.5 ton and greater. These trucks could be outfitted with either gauge depending upon usage.
Contrary to popular myth, there was never a clock uption offered. You can retrofit some early GM clocks and make it look "factory". The stuff legends are made from.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-23-2003, 02:28 PM   #17
rickspickuppart
clock dash
here is our cluster, (like said before it's not factory) we got the clock out of some GM car and made it fit.
[IMG]http://www.****************.com/boardpics/clock1.jpg[/IMG]
rickspickuppart is offline   Reply With Quote
Old 09-23-2003, 02:31 PM   #18
smitty62
smitty62's Avatar
Rick;
Do you remember what car it came from? I'd like to have one!
Smitty
Old 09-23-2003, 02:35 PM   #19
rickspickuppart
it's been a few years we think it was some kind of early 70's buick
Old 09-23-2003, 03:07 PM   #20
smitty62
smitty62's Avatar
OK--thanks
Smitty
Old 09-23-2003, 04:36 PM   #21
MJN
MJN's Avatar
My amp gauge never used to move, then I changed one of those fueses in the harness and it moved for a while, then it just quit, the fuses looked good and never had a problem with it. I am having problems now though, bad connections somewhere. Gauge hasn't moved for a while now though. oh well
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 09-23-2003, 04:53 PM   #22
palallin
My old printed circuit board had some broken leads; that was part of my problem. I will have to wait till I get the old guy back together to know whether I've cured all the problems.
Old 09-24-2003, 02:53 AM   #23
Edmond
Edmond's Avatar
Originally posted by smitty62
Rick;
You can also use one from a second generation Camaro
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 09-24-2003, 01:02 PM   #24
Hooter
My other Love
Hooter's Avatar
since my truck has such a big grind on the cam, when the truck is idling the ammeter guage tends to twich quite a bit, so I know mine is working.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-25-2003, 01:41 PM   #25
BadAssChevy502
Yeh It's Fast
Re: Re: Bad gauge
Hey thanks for the info
