Old 02-17-2016, 01:45 AM   #1
hotrodguy992609
porterbuilt panhard bar nowhere near level
hello i got this kit last year just now starting to finish it all up. i am using the mild drop member with hq coilovers. does have bolt in step notch. i mounted the panhard bar from the driverside step notch bracket to the bottom hole on the trailing arm. with at ride height of 8 inches frame to ground at cab mount it is no where near level. i know this isnt correct. has anyone else had this issue? figured i check here first the pb guys are always busy. is it possible i have a wrong trailing arm or notch bracket? the hole in the notch bracket needs to be raised about 1 1/4 then at ride height panhard bar would be level. thanks for the help
hotrodguy992609 is offline   Reply With Quote
Old 02-17-2016, 01:41 PM   #2
sduckworth13
sduckworth13's Avatar
Re: porterbuilt panhard bar nowhere near level
Post a picture up. There are a few guys here that have run the PB adjustable trac bar.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-17-2016, 09:16 PM   #3
Grumpy old man
Grumpy old man's Avatar
why does it need to be level
Grumpy old man is offline   Reply With Quote
Old 02-17-2016, 09:49 PM   #4
Ruscal
Less lateral movement when level. Keeps truck centered best.
Russ
RC
Ruscal is offline   Reply With Quote
Old 05-08-2016, 10:32 AM   #5
hotrodguy992609
sorry guys for not responding. I got hurt on the job and been out of work and now fixing to have back surgery. but just wanted to let you know. Nathan took full care of the issue. super super great guy. looked like he actually sent the setup for the lowest kit possible. but he had me measure few things and he said it was wrong and couple weeks got the correct parts and looks great. great product and customer service. they need to hire few people was the only problem I had under staffed.
