02-17-2016, 02:25 PM | #1 |
Fitting a Dana 80?
I have heard of a few guys putting Dana 80s in there C10s but I have never really seen some good pictures of the fit. Does anyone have details on this? What size u-bolts are used and are modifications needed to the trailing arms?
I have a 68' C10 Suburban and a dually Dana 80 I want to put in it. Thanks |
02-17-2016, 09:57 PM | #2 |
Re: Fitting a Dana 80?
Why a massive 80. I just put in a D70HD in a chassis I'm working on. That thing is pretty damn beef. An 80 is even more so
02-18-2016, 10:26 AM | #3 | |
Is the D70HD a 4" axle tube? What size U-bolts did you use? Thanks for the response by the way. |
02-18-2016, 12:55 PM | #4 |
I had to have the u-bolts made for the leaf spring pack I am using
02-18-2016, 01:05 PM | #5 |
02-18-2016, 09:03 PM | #6 |
If you want beef, why not a 14 Bolt? They are a dime a dozen, cheap, lighter than a D80, have a lot of aftermarket support (gearing), and much easier to adapt to our trucks. I put one in the rear of my Blazer. Doesn't seem like the installation of the D80 will be worth the effort. But hey, its your project! Just be sure to post up pictures!
02-19-2016, 09:29 AM | #7 | |
What is the size of the axle tubes on the 14 bolt? |
02-19-2016, 09:51 AM | #8 |
One thing to consider is the added unsprung weight of the Dana 80. Typically wouldn't be an issue with a leaf spring truck but those light duty coils might need to be beefed up to keep the rear end in control.
02-19-2016, 10:12 AM | #9 | |
Does that sound like the right idea? All suggestions and advice helps. I appreciate it. |
02-19-2016, 10:32 AM | #10 |
I am definitely no expert in that field but I think you may have an issue only because you are probably adding at least an extra 150 lbs if not more (much larger drums, 4 rims and tires, that heavy drum hub assembly that slides over the axle tubes, etc).
Buy the heaviest duty crap you can stuff under there and see what happens. I have a leaf spring rear 72 C20 and I though about putting a narrowed dually set up under it at some point so this is kind of cool with the burb. |
02-19-2016, 12:30 PM | #11 |
Proprietor of Dale's Corner
Are you planning on narrowing the differential or adding step fenders?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
02-19-2016, 01:06 PM | #12 |
I am going to add dually fenders. Measuring, I will need at least 6" fenders. My plan is to get this all driving by Julyish so it is not going to be pretty. After its driving and reliable I may make the body pretty. But for now my story is "RatRod".
02-22-2016, 12:51 PM | #13 |
Does anyone know what the wall thickness of the Dana 80 axle tube is?
02-22-2016, 04:22 PM | #14 |
Your local law enforcement may not look favorably on the open wheel concept with the outer tires protruding completely beyond the fenders. You may have to fab up the dually fenders sooner than you think. Just something to consider.
02-22-2016, 09:21 PM | #15 |
02-22-2016, 09:27 PM | #16 |
Dana 80 tubes are 3 5/8 inches in diameter and 9/16 inch thick
02-23-2016, 09:43 AM | #17 |
Yes, of course. Good point. I will not be driving it without fenders. I think I need marker lights as well.
02-23-2016, 09:44 AM | #18 |
05-10-2016, 09:45 AM | #19 |
If anyone is curious I am now trying to figure out the axle seat situation for this Dana80. Any suggestions on how to make or where to buy some?
I started the below thread to specifically ask this question: http://67-72chevytrucks.com/vboard/s...d.php?t=706562 I am working though modifying the trailing arms now to except the larger U-bolts. |
05-10-2016, 10:21 AM | #20 |
You do realize a D80 is way overkill for that C10, right? Sure, it'll look cool, but it seems like a lot of effort to have an axle that the rest of the chassis can't possibly match in load capability. I could see a 14 bolt, but even so the HD 1/2 ton axle in these years was a D60 if I'm not mistaken. That's what I have in my '67 C10 and it's been overhauled once in 330,000 miles of towing, hauling, long tripping, etc. Dad's '86 K20 has a semi-float 14 bolt that's seen the GVW exceeded more times than I could count over its 361,000 miles and AFAIK it's never been apart. I like full-floating axles as much as the next guy (have a FF 14 bolt in my '85 C3500) but based on the vehicles I've spent years with/around with semi-floating axles there's really no need unless they're being used in such capacity as would warrant a heavy duty 3/4 ton or 1-ton running gear.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
05-10-2016, 10:46 AM | #21 | |
What I am looking for is anyone's advice/help on how to make it work. |
05-10-2016, 10:52 AM | #22 |
In spite of the impracticality, I get it. Have you sized up the Ram chassis and weighed the merits of just putting it under the 'Burb body with a big honkin' 502 or 8.1/4L80 combo, or something along those lines?
05-10-2016, 11:01 AM | #23 |
I thought of that. the frame of the RAM is quite a bit wider and the wheel base is much longer so I would have to do significant frame mods either way. I just figured this way might be the rout to go. It will save me some body mods and I really wanted the training arm rear suspension. the whole drive line (Cummins 12v & 6-speed) of the RAM is going in the C10 too as well as the front cross member (disc brakes, power steering, IFS, 8-Lug).
05-10-2016, 11:01 AM | #24 |
+1. I was about to suggest the same thing.
05-10-2016, 01:50 PM | #25 |
Sound logic, I'm sure. On a 2WD I'd want trailing arm suspension, too. I assume this means an 8-lug conversion, too? Wish I was closer so I could snap up your wheels.
