Got big-block?
![]() Join Date: Jul 2000
look at this dual snorkel ram air box I put together for the work truck...
A guy was selling these homemade dual snorker aircleaners at the Arlington swapmeet for $30. I painted it a wrinkle black finish, and got the dryer vent hoses from Home Depot. I think it looks great on my '93 work truck. Something different anyway. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
Got big-block?
pic2
Cool, now if you can figure a way to "force" air into them.
KEEP ON TRUCKING
looks good by the way i recieved the ps setup thanks for a smooth transaction
72 cheyenne 2wd lwb 71 k20 sons bassett va |
.... work truck???? lol thats far from a work truck
70 longbed 496/th400/Ford 9" |
Got big-block?
Yeah, I just ran one hose to an open spot behind rad support but in front of the battery on the pass side, then the other hose to a nice open spot in the rad support behind the driver's side headlight. I'm sure they don't pull as much air as was going through the previous open element aircleaner I was running, but it's probably pretty close, and it really cut down on the loud "hissing" noise tbi's make when you put an open element aircleaner on
![]() 72shadetree, glad you got the ps set-up OK. Thanks for the fast payment and easy transaction. SC |
looks sweet
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
Thats cool...I would pay some $$$ to get one of these....
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
what size filter are you running in that home made ram air box ? i too bought one and my 14 inch filter doesnt fit in. any info would be a great help
PROJECT 7DEUCE
![]() Join Date: Dec 2002
If that truck has the small square glass light's you could take out the highbeam light and make it look like a thunderbolt with the stainless mesh to keep bird's and other large dabree out... But then you would have to find a small high/low beam light for the outter hole? The motor on the bottom look's cool but I do not see how the solid heatercore line would last to long with the motor movement???
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#11 | |
CCRider
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
SC, that system looks great, especially for $30. I would think you're actually better off w/that set-up compared to the open element because your actually pulling in cooler/denser outside air vs. underhood heated air.
