Old 02-18-2016, 02:33 PM   #1
cpeitsmeyer
1981 c20 air conditioning click
My 1981 Chevy c20 is making a clicking sound every 5 seconds or so when the ac is turned on. It also sounds like more energy is being pulled from the engine when it is clicking. The ac also takes for ever to get cold. I just refilled the freon if that helps at all. Any input of what the problem could be would be a big help. -Thanks!
cpeitsmeyer is offline   Reply With Quote
Old 02-18-2016, 05:34 PM   #2
truckin 79
Re: 1981 c20 air conditioning click
It sound like the clutch is probably what is clicking. You probably are still low on Freon if it is taking for ever to get cold. Do you have a gauge to see how much Freon is in the system???
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 02-18-2016, 08:03 PM   #3
cpeitsmeyer
The only gauge I have came with the can of refrigerant and I filled it to wear it said to. The clutch is only spinning for maybe 3 seconds and then it turns off for five. It will do this the entire time it's on.
Old 02-19-2016, 08:00 PM   #4
truckin 79
Yeah that definitely means the system is low. The compressor will stay engaged once there is enough refrigerant in the system. The low pressure switch protects compressor from being damaged from to low of refrigerant
Old 02-24-2016, 10:30 AM   #5
tlawre87
tlawre87's Avatar
The system could also be overcharged and the high side switch is kicking off the compressor. You're best bet is to get a set of manifold gauges and see what the high and low side of the system is doing.
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
