02-19-2016, 11:44 AM | #1 |
Rear Air Ride set up
Hey guys. Im new to the forum and and bagging trucks and so i dont really know how to work this. I have a 1969 chevy c10 longbed I have bagged but I want to lay frame. What kind of set up would I use for the rear to do that? do i need a four link? or can i use trailing arms? thanks
02-19-2016, 01:04 PM | #2 |
67-72 parts collector,…
Re: Rear Air Ride set up
Look here for parts and info:
www.pbfab.com
02-19-2016, 01:40 PM | #3 |
is there a website that offers a rear drop member thats not so much?
02-19-2016, 01:55 PM | #4 |
I'm planning to do this, but build my own frame.
You will need to step notch the frame. You can buy step notches, or you can build and weld your own. The stock trailing arms can be used, as long as they clear the frame when it lays out. The rear bags have to be relocated further up the trailing arm. I've heard it rides better than bags over axle. |
02-19-2016, 02:12 PM | #5 | |
02-19-2016, 02:32 PM | #6 |
Here's what one guy did. He said he had to add 2 inch blocks under the axle to lay frame.
See where the trailing arms hit the frame? You can modify the frame so you don't have to use blocks. Link to his thread: http://www.stanceworks.com/forums/sh...t=12108&page=6 |
02-19-2016, 05:47 PM | #7 |
2WD Jimmy
This is a really good dependable setup. http://www.earlyclassic.com/catalog.aspx In the keyword box, type in 'rear air ride'.
02-20-2016, 11:39 AM | #8 |
thanks guys. I didnt have much luck with that last website. Are there any other ideas for the rear to lay frame? pictures?
02-20-2016, 11:48 AM | #9 |
Plenty of different setups in google images. But this one using the stock trailing arms is the simplest. Any way you look at it, it's a huge job to take on. If you can weld, you're better off just buying some metal to build your own frame.
09-18-2017, 09:58 PM | #10 |
where are the shocks located on this setup ?
