![]() Join Date: Jun 2012
bumper guard install
Anyone have any pics or the instruction sheet I could have a look at?. Just want to make sure I get them on there right
Thanks Tom
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
Re: bumper guard install
I have the original instructions. I'm sick in bed but will try to get out and take a pic of them for you.
Here you go. Hopefully the board doesn't resize it too small!
Thanks Dave! You didn't have to do that though
I didn't know I had to drill a hole in the bumper though
![]() Join Date: Jul 2001
I don't think you would have to on the 71-72 tall versions. I've removed several of them over the years and there wasn't any extra holes.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
I don't know, those instructions above say to, although those are the earlier ones it appears. Here is what I have.
Always happy to help a veteran, and it only took 3 minutes!
As for drilling the hole, you do on the '70. I mocked up an install using the supplied bracket and a rare earth magnet, which seemed to work - but I wasn't going to be drilling any holes. Ultimately I decided not to install them, since I thought it didn't enhance the look of my particular truck. Not sure how well it would have held up. I also grabbed a set of "rubber door edge guard" to use as an edge protection so that it didn't scrape up the bumper underneath.
I appreciate that
I've got a 71 c20 and ordered new bumper guards and chrome front bumper from classic Chevy and I installed mine today using just the single bolt provided. It did not line up at all. Tomorrow I will be drill holes in the bumper for the bottom bolt.
1971 c20 LWB Fleet 2wd 'working' Add-on AC & Working heat/defrost manual transmission w/ Power steering & power brakes Family owned since 1971 ![]() ____________________________________ “Life is rough so you gotta be tough” - Johnny Cash |
Thanks for the info, not what I wanted to hear though...
There were two styles for bumper guards...67/70 and 71/72. The earlier ones are shorter, all chrome, and mount outside of the frame where Dave's instructions show. The 71/72 style mount at bumper mounting location at end of frame. When mounting the 67-70 style in the inward location (same as 71/72) they will fit better with a little careful grinding.
Those 71/72 guards just bolt up where the bumper does on the frame ends
#13 |
Thanks Tim, I'll give it a better look
#14 |
You should have a bracket that just hooks to the bottom of the bumper. If not, they are easy to make.
Let me see if I can remember how to post a pic.....
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
#15 |
Ahhhh......Nope don't have that bracket. Thank you for that
#16 |
Always on the hunt...
![]() Join Date: Sep 2006
Here is an old saved picture from our archives to go with Tims above post about the different bumper guard styles, it also shows your missing brackets. We do have NOS bumper guards on hand in the parts stash so if you think that you are in need yet, I could get you some pics of the mounting instruction sheet your style. Let me know, Mel.
#17 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#18 |
Just so you know, I have had no problem running the 71/72 style w/o the bottom bracket. If the bolt through the bumper is good and tight, as it should be, the guards will stay in place just fine. Might want to take a look every now and then to see if they've been bumped. The brackets are simple enough to make, yet I never got around to it on the truck I ran w/o them
#19 |
Thanks Mel. I'll take a pic of the instructions if you don't mind.
Tim, did you use both bolts on the guards to the frame?
#20 |
Like Tim said, the bottom bracket is not really necessary, but I have always made one 'just because' They will mount using only the bottom carriage bolt from the front of the bumper.
I am also curious to see the instructions from Mel to see what they say. Just because I've always done it one way don't mean it's right!
#21 |
Thanks acorn
#22 | |
#23 |
Thanks Mel! Been busy here too
