Old 02-19-2016, 04:26 PM   #1
Coach529
Coach529's Avatar
Air Lines
I am about to start running air lines. Any advice??
Placement. I was thinking about sleeving it in some places with some 3/8" pex to protect it. Is this needed?
I was going to hold them down with rubber lined P clips.
How far away from heat is safe?
I am running a full manual set up with the valves and gauges pictured below.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-19-2016, 08:59 PM   #2
BigMike
BigMike's Avatar
Re: Air Lines
I finished up my 69 about 6 weeks ago & it was fun. I used the same rubber insulated clamps you're going to use. I just made sure it wasn't going to rub against anything, and the parts that did I put a rubber hose around the DOT line to protect it. As long as it isn't rubbing against anything I think you'll be okay. I still have a tiny leak some where. The bags will stay inflated for weeks and not drop, but the tank will run out of air in about 2.5 to 3 days. Once I'm healthy enough I'll try & track the leak(s) down. Had hip replacement surgery 5 weeks ago so still a little weak.
BigMike is offline   Reply With Quote
Old 02-22-2016, 12:44 PM   #3
Coach529
Coach529's Avatar
Re: Air Lines
Thanks for the feedback Mike. Get well soon!!
1949 Chevy 3600
