Old 02-19-2016, 07:05 PM   #1
OldChevy61
OldChevy61's Avatar
Removing switches
Got my 62 cab stripped and ready for epoxy, well all but the switches,lol. How do you get the CIG lighter out, ignition switch has a ring but apparently a combination to get it off. Headlight switch? Wiper switch I'm good. Choke? Last thing holding me up spraying tomorrow.
OldChevy61 is offline   Reply With Quote
Old 02-19-2016, 07:25 PM   #2
Nanook
Nanook's Avatar
Re: Removing switches
Headlight switch has a button on the side (on the body behind the dash) Press the button and pull on the knob.
To remove the ignition, you will need the key and a paper clip. I believe you turn the key to the accessory position and insert the paper clip into the small hole next to the key.
Good Luck
Nanook is offline   Reply With Quote
Old 02-19-2016, 10:35 PM   #3
DPowers
DPowers's Avatar
u get them out ok?
DPowers is offline   Reply With Quote
Old 02-19-2016, 10:51 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
http://www.earlyclassic.com/tech.asp...064-66%20Chevy
The headlight rod and knob are removed by first pulling the rod to the on position and by reaching under the dash and depressing the spring- loaded button found on top of the headlight switch itself. Depressing the button allows the rod to slide out of the switch, and the bezel can now be removed.
66 C20 Service Truck:
Old 02-19-2016, 11:05 PM   #5
OldChevy61
OldChevy61's Avatar
Not out yet. Haven't been back out to it. They will be out in the morning. The one that really stumps me is the CIG lighter. I found a set screw on the wiper switch, so that's covered, choke has a nut on it, thanks for the help on the headlight switch and ignition switch. Ready to get this thing epoxied and primed.
Old 02-19-2016, 11:13 PM   #6
DPowers
DPowers's Avatar
cig lighter is two pieces and unscrews from back of cluster.
Old 02-20-2016, 11:21 AM   #7
OldChevy61
OldChevy61's Avatar
Got em all out...Thanks guys,I was about to start ripping and tearing,lol. Now to shop vac the blasting media out, blow off and wipe down.
