Old 02-20-2016, 11:18 PM   #1
conman585
conman585's Avatar
73-87 frame differences
Hey guys. I have a 1977 2wd SWB C10. I'm thinking about building up a swb frame to my liking w/ some PB and other suspension parts as a side project. Once it's built up I'd like to swap my current bed/cab/clip over to it. Bottom line will any 73-87 frame work? Any major differences between the years? Cab mounts, dimensions etc. I want to be able to drive my truck and not rip it apart to build it up how I want.
conman585 is offline   Reply With Quote
Old 02-21-2016, 02:52 AM   #2
karl
karl's Avatar
Re: 73-87 frame differences
Your better off using a frame from 73-80. The 81 up frame will work but your going to run into problems.
karl is offline   Reply With Quote
Old 02-21-2016, 01:22 PM   #3
bdiamond
The core support mounts are in a different spot and the frame horns are different for sure.
bdiamond is offline   Reply With Quote
Old 02-21-2016, 02:08 PM   #4
slotard
I believe there are some differences in frame height/thickness over the years as well, I don't know how significant they are.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf claims the section modulus for a 73 C10 SWB is 3.06
https://www.gmheritagecenter.com/doc...olet-Truck.pdf claims the section modulus for a 79 C10 SWB is 3.14
https://www.gmheritagecenter.com/doc...olet-Truck.pdf claims the section modulus for an 87 R10 is 3.10
I know I've seen more significant differences for 3/4 tons.
And yes, bumper/core support mounts are apparently a little different as well.
1973 C20, 350/350
slotard is offline   Reply With Quote
