Old 02-21-2016, 02:58 AM   #1
karl
karl's Avatar
Wiring Harness??
77 C10. Does anyone have a pic of the wire routing from the firewall to back of truck? I assume the harness runs along the inside of the frame along the drivers side? Thanks
karl is offline   Reply With Quote
Old 02-21-2016, 09:56 AM   #2
chrismoore701
chrismoore701's Avatar
Re: Wiring Harness??
I am about to run my wires to the back. I am going to run along the inside of the frame and hang them with self taping screws to the frame.
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 02-21-2016, 05:22 PM   #3
ray_mcavoy
I don't have a photo, but if I remember correctly, the rear light harness comes down from the firewall and runs along the outside of the frame to keep it away from the exhaust. Then it crosses over the top of the frame just behind the rear cab mount and runs the rest of the way back along the inside of the frame.
ray_mcavoy is offline   Reply With Quote
Old 02-23-2016, 12:09 AM   #4
Pontiac1976
Pontiac1976's Avatar
That last post is right on.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 02-23-2016, 09:24 PM   #5
russgt
russgt's Avatar
On my 76 K5, the tail light wiring ran down the inside of the drivers side frame rail. The gas gauge wire ran on the inside of the passenger side frame rail.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
