Old 02-21-2016, 10:43 AM   #1
Sicklajoie
The Niner
Sicklajoie's Avatar
Antenna question.
Right now with my antenna, no matter how I mount it, it angles 20 degrees inward. Does anyone sell a bezel so that the antenna sits perfectly upright? Or do I have to be on the lookout for an NOS piece?
Thanks.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-21-2016, 11:50 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Antenna question.
Thanks.
If it is a stock antenna it should be adjustable. There will be a half moon shaped piece inside the cowl that you can rotate to adjust the angle.
LockDoc
Leon
Old 02-21-2016, 12:59 PM   #3
FirstOwner69
FirstOwner69's Avatar
Does your SPID have a radio listed? The reason I ask is that pictures in your "progression"/build thread seem show the antenna hole in the cowl too close to the hood. That could indicate that a radio was added later or that the cowl was replaced. I don't think there is enough latitude of adjustment in a factory antenna to get it vertical in that location. It might help to post a close-up picture.
FirstOwner69 is offline   Reply With Quote
Old 02-21-2016, 01:42 PM   #4
Sicklajoie
The Niner
Sicklajoie's Avatar
I'm pretty sure it's the bezel itself. There should be one that's got less of an angle on the bottom, correct?
Old 02-21-2016, 01:48 PM   #5
67 chevelle
67 chevelle's Avatar
Yeah thats not the stock location
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-21-2016, 01:58 PM   #6
FirstOwner69
Your antenna appears factory correct. The location is not. Here's a picture of mine showing where GM put them.
Old 02-21-2016, 05:10 PM   #7
Sicklajoie
The Niner
Sicklajoie's Avatar
Ok, thanks for the replies..
Old 02-21-2016, 07:59 PM   #8
Sicklajoie
The Niner
Sicklajoie's Avatar
I dug up some old photos of my truck, and the antenna's in the same spot, but it's definitely got a different bezel so that it's upright.
Old 02-21-2016, 08:54 PM   #9
Classic Bowties
Always on the hunt...
LockDoc
Leon, you may be thinking of a universal mount type antenna with the adjustable base and that half moon piece. Given their design, the factory OE and OE style reproduction antennas are NOT adjustable if mounted correctly in the factory location. There is a locating lug at the base of the chrome bezel that matches the indexing notch in the cowl, once you tighten the upper nut onto the threads of the antenna body everything pulls tight together, see below pictures. Mel
Classic Bowties is offline   Reply With Quote
Old 02-22-2016, 10:20 AM   #10
Looks like someone added the aftermarket (or OEM from other vehicle) antenna , then later on it was replaced with original truck antenna, either when painted or because it broke.
Old 02-22-2016, 01:58 PM   #11
Sicklajoie
The Niner
Sicklajoie's Avatar
Ok. Thanks again everyone.
