02-21-2016, 02:45 PM | #1 |
Help! these pulleys are making me crazy
My power steering pulley does not line up what do I have wrong. I thought I had all the right stuff but I guess I don't.
02-21-2016, 03:02 PM | #2 |
Re: Help! these pulleys are making me crazy
I had a similar situation. I just put a double sheave on the alternator nose and used the forward groove.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-22-2016 at 08:24 PM. |
02-21-2016, 03:19 PM | #3 |
Wrong lower pulley
02-21-2016, 03:33 PM | #4 |
What does the lower pulley suppose to look like
02-21-2016, 03:56 PM | #5 |
72 350 pulleys.
The lid is stuck on my jar of anti seize |
02-21-2016, 06:18 PM | #6 |
I'd change the pulleys
02-21-2016, 07:42 PM | #7 |
Ok thanks i guess i on the hunt for another pulley
02-21-2016, 07:43 PM | #8 |
When I was putting my 72 GMC 1500 4x4 together I had a similar stiuation I couldn't find the proper pully for the power steering pump so I ended up using a 4 groove crank pulley and just left the 3rd groove from the inside empty. It works fine and I've never had a belt jump off
Ugly 61 |
02-21-2016, 08:02 PM | #9 |
Always on the hunt...
If you are able to read the pulley p/n on your pump, let me know know the # and I may be able to tell you the p/n for the matching outer crank drive pulley. Mel
02-21-2016, 10:03 PM | #10 |
The part number is 3925537DC
02-22-2016, 09:16 AM | #11 |
I have an extra set of pulleys I had powder coated black, when I get home from work this evening, I'll take a few pictures and post them.
If they might work, you can have them for the cost of postage. Ben |
02-22-2016, 10:53 PM | #12 |
02-22-2016, 11:00 PM | #13 |
I have to dig through my stash first thing in the morning, I remembered I moved a rubber maid tote out to my storage shed, And I'll snap a few pics showing the diameter and depth using a tape measure, perhaps that will give you a better Idea of whether these will work for you.
Ben |
02-23-2016, 12:21 AM | #14 |
I don't think you have the correct lower crank pulley setup on there now, can you take a better picture, a little closer with flash on the power steering pulley too?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-23-2016, 12:39 AM | #15 |
Looks like in the first pic that both the alt and power steering do not line up? Is that correct?
02-23-2016, 01:04 AM | #16 |
02-23-2016, 01:05 AM | #17 |
02-23-2016, 01:29 AM | #18 |
I have a set of proper pulley's in my garage and pictures on my home computer i can post later but they look like the set in post 5, the one set on the engine looks like its from a long water pump setup.
I am questioning you power steering pump, mounts and pulley at this point.
02-23-2016, 05:38 AM | #19 |
Here they are.
02-23-2016, 08:53 AM | #20 |
Its kind of a bad photo I took but the alt lines up just the power steering is to far fwd. What does the correct power steering brackets look like
02-23-2016, 08:58 AM | #21 |
Mine aren't even close to that, much deeper on the bottom pulley, don't know about the water pump pulley, figures I forgot to grab them on my way out the door this morning.......
Ben I'll get those this afternoon for sure. |
02-23-2016, 03:25 PM | #22 |
Per our old archived short water pump pulley records, we have used your listed p/s pump pulley p/n 3925537 with outer crank two groove add on drive pulley p/n 3923898 on small block applications and also with outer crank single groove add on drive pulley p/n 3925525 on the big block applications. If you end up sourcing a different pulley setup, another very common small block short w/p pulley combo for p/s is pump pulley p/n 3993325 used with the outer crank single groove add on drive pulley p/n 3751232. Hope that helps some, Mel.
02-23-2016, 04:26 PM | #23 | |
02-24-2016, 01:27 AM | #24 |
interesting pulley. that puley is identicle to a pully used on an aftermarket ac unit instaled on my 68 k20.
I will burn off a picture of a correct pulley that may work for your alternator. its wider than a single groove style but not as wide as a 2 groove pulley. took for ever to find it but there it was, in a corvette catologe......and priced accordingly....ouch |
02-24-2016, 03:30 AM | #25 |
Old member
Couple of my old setup.
