02-21-2016, 06:32 PM | #1 |
About cams, valves and timing positions...... Help?
Paul Y also came over early to supervise (well, he did all the work as he has built a few engines and knows his way around) he also tried along with Martin to teach me stuff, I think I make a good cuppa tea though.
No smiles today...... I took photos of stuff in position and also the progress, that is my job. I did help find some nuts n bolts and made a few bits up. Ohhhh, and another useful tool....... Keeps stuff in position. Simple. Moving stuff about. Very good news.... It's a four bolt main. And the oil pump has been upgraded. Then when the front end got opened.... Timing chain good. But note the position of the timing marks......... Way out it seems. With the camel hump heads off, it was found that most of the exhaust valves were missing their valve stem seals. The engine has definitely been rebuilt previously, block has been decked, it has a +30 overbore with the cross hatching very visible, new brass freeze plugs, new oil plugs, oil pump, you get the picture. In the truck the engine was running fine, and the reason for the tear down was that is was using a lot of oil and low compression on No 1 (both wet and dry). Think we have found the problem for the excessive oil use, lack of valve stem oil seals on exhausts, and a build up of carbon under the exhaust valve on No.1 giving a bad seal against valve seat. Upon disassembly the whole engine smelt of burnt oil and the heads and pistons had a heavy coating of oily carbon. Maybe because it has a broken valve spring, that valve has a mushroomed valve stem (and may possibly be bent) The cam itself is undamaged, the lifters are good and the pushrods are straight. So, the need to identify it is to ensure that the correct valve springs are procured and the mystery of the off timing marks can be solved. What are the markings on the cam then ? Glad you asked - This is what is cast into the cam EP6 30 D8 C8 C5 CWC There is also Blue and Purple paint on the distributor drive end of the cam and a 2 white spots half way down. On the distributor end there is also an A punched into the shaft. Other than that there are no marking or casting number. I 'think' that it is a Chevy cam rather than an after market item but happy to be proved wrong. Spring has sprung. So that then was the fun for today. Seems the motor needs a few bits to get it back together. A valve, springs, clean up and some info as tow hat motor this may be, so that I know what springs to buy. Thanks as always to helping friends, Paul and Martin. Back to normal tomorrow.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
02-21-2016, 07:42 PM | #2 |
Re: About cams, valves and timing positions...... Help?
Timing marks aren't off!
Crank the motor around until the keyway in the crank sprocket is at 2 oclock and if the dot on the cam gear is at 12 oclock you're on #6 tdc. To get to #1 tdc and the dots to line up, just rotate the crank one turn. Then the cam dot will be at 6 oclock and the crank gear will be at 12 oclock. Never assume the timing chain is good. I can see slack in it. Get a new one. Also never re-use an old cam unless you're dirt poor. Nice pics though!! |
02-21-2016, 08:36 PM | #3 |
On these older engines the exhaust valves used what looks like an oring with square sides at the retainer and not an unbrella seal like was on the intake. There is not any suction on the exhaust like on the intake so that type of seal was fine. If it is using oil I would rebuild the engine and for all means put a cam and lifters in it. Looks like your lower timing gear has a few key slots and that will have more than one mark on it to line up based on advancing or retarding the cam.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-22-2016, 02:58 AM | #4 | |
Thanks a lot guys.
Remember, you are speaking to me which means I know verrrry little so all learning is great. Here's a reply from Garage Journal. Quote:
02-22-2016, 01:24 PM | #5 |
How many miles will you be driving? I bet less than 5000 per year. Looks like it is a nice hobby for you, as of course it is with most of us. IMO it doesn't need to be built to go 200,000 miles.
If it were mine and me always on a budget; clean it up, replace broken parts, rings, bearings and gaskets. Chain looks OK to me (replace if you want), replace lifters. Happy motoring. |
