Old 02-21-2016, 08:30 PM   #1
TheCougarine
TheCougarine's Avatar
Alternator Replacement Question
Hey guys, so the alternator on my 71' is toast and I need to replace it but I really don't know very much about them so I'm kind of lost on what I need to buy. Could someone help me out and tell me what would be a simple bolt on replacement for the alternator on my truck? Thanks in advance.
TheCougarine is offline   Reply With Quote
Old 02-21-2016, 08:40 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Alternator Replacement Question
I used a later model 64(?) amp Delco 10si internally regulated alternator. Is bolt on and with a few very simple wiring mods it by passes the external regulator system that the O.E. unit uses. They can be found on square body trucks amongst many other applications. They are readily available at the local parts stores.
Tyler
57taskforce is online now   Reply With Quote
Old 02-21-2016, 08:46 PM   #3
davepl
davepl's Avatar
I generally take an opportunity like this to convert to an internally regulated alternator, but if this one was meeting your needs before it failed, just get the direct replacement at your favorite parts store. Don't change anything.
If it -wasn't- putting out enough for your truck, read up on the conversions.
Stay away from the seduction of "one wire alternators". You lose a number of features, like the idiot light, field excitation, and so on. You have to (usually) rev them up to get them to start charging the first time too.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-21-2016, 09:19 PM   #4
DTMsurf
I would just get the OE replacement from your nearest auto parts store. I'm running one and it is working just fine on my 72.
DTMsurf is offline   Reply With Quote
Old 02-21-2016, 09:59 PM   #5
TheCougarine
One last thing, is it possible the voltage regulator is bad and causing the alternator to put out a low voltage? Is there a way to check that separately?
Old 02-21-2016, 10:28 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I'm replacing my perfectly good alternator for one internally regulated. Unfortunately I'm still using the one I have. Don't know about the wiring, but it doesn't matter anyway, because I'm replacing all that too.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 02-21-2016, 10:39 PM   #7
davepl
davepl's Avatar
Most auto parts stores can bench-test an alternator. If it's fine, then I'd suspect the regulator.
Growing up on the prairies where the next "big town" can be 6 hours away we used to carry spare belts, water pump, regulator, alternator, and fuel pump. Those are the "maintenance" items on a GM of that era.
