Old 02-22-2016, 12:57 PM   #1
Centex84c10
Centex84c10's Avatar
rearend swap questions
Hello everyone. I'm new to the site but have been using it for most if my truck build. I'm restoring a 1984 c10 swb and have questions on the rearend. Currently there is a 1976 12 bolt being used with 3.73 gears. It has open differentials and I am wanting a limited slip. My question is should I buy a posi unit and have it installed or swap to a newer rearend. I am also wanting rear disc. I haven't been able to find an old thread to help me figure out what will work. Any and all help is appreciated.
Centex84c10 is offline   Reply With Quote
Old 03-01-2016, 08:41 PM   #2
67-72C10
67-72C10's Avatar
Re: rearend swap questions
The newer rear ends are wider than your factory rear.You can use it but will need wheels with a offset like the newer trucks have.Then you would need spacers for the front to have a matching set.
There are 12 bolt posi units for trucks on the internet for around $300.Maybe cheaper on craigslist.You can also buy weld on brackets for your rear that use GM front calipers and slip on rotors.I think afco has bolt on ones now too. (You would not have a ebrake with this setup)
Hope this helps...
Steve
67-72C10 is offline   Reply With Quote
Old 03-08-2016, 01:09 AM   #3
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Welcome to the site. I'm not much of a rear end guy. Where in CenTex are you? As far as disc brakes you can check out http://www.ruffstuffspecialties.com/catalog/Weldon.html I buy a bunch of stuff from them, really good company.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
