Old 02-22-2016, 02:30 PM   #1
bbobb
How do i measure . Help please
I need a formula on how to measure for a static drop lowering kit for my 72. Any help would be appreciated
69 C10 long box
All factory 55 Lincoln Capri
50 Buick Hardtop sled
30 Tudor sedan
bbobb is offline   Reply With Quote
Old 02-22-2016, 06:04 PM   #2
SoCoC10
SoCoC10's Avatar
Re: How do i measure . Help please
There is a thread on this site titled "Let's see your static drops" loaded with pics. I can tell you the DJM rear flip kit I put on a 69 GMC with leaf springs tells you to measure from the wheel/hub center to the fender lip. I ended up with 5-5 1/2" drop.
When guys say truck is lowered 7" front 10" rear they are full of s%*t. They are measuring from the ground up and are going from 235/75/15 tires to 245/45/20s. Take your time, do your research and buy once. Good luck.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 02-22-2016, 07:38 PM   #3
bbobb
Thanks for the reply. I will try this in the morning
69 C10 long box
30 Tudor sedan
Old 02-22-2016, 11:44 PM   #4
69chevy lwb
69chevy lwb's Avatar
I think your facts are a bit misleading on tire size. There is a 0.2" different between the two tire sizes you mentioned. Also you can static drop the truck a half inch off the ground if your little heart desires. It would be the world's most useless truck but the ground is the limit for lowering.
69chevy lwb is offline   Reply With Quote
Old 02-23-2016, 11:04 AM   #5
bbobb
All i am trying to to is lesson the gap between the tires and lip of the fender.
69 C10 long box
30 Tudor sedan
Old 02-24-2016, 10:04 AM   #6
Mike C
Mike C's Avatar
The measurement you want is from the center of the hub to straight up to the bottom of the fender.
Wheel and tire size can affect the ground clearance as well as the height of the roof from the ground but don't have anything to do with how much you lowered the suspension.
On my 69 short step the 2 1/2" drop spindles and 2" ECE small block springs lowered it almost exactly 4 1/2".
And FWIW, the DJM flip on my 5 leaf HD spring C10 dropped my truck 7". On a leaf truck not just the arch of the spring but the thickness of the leaf pack contributes to how much it's lowered based on how high it was to begin with.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
