02-22-2016, 05:36 PM | #1 |
Crazy Fig is at it again with the A.D.D.
Ok, my boss is selling me some wheels that will fit my truck.
I'm trying to figure out how to achieve this look. The problem is that i'm pretty sure no one has done this before. I would like to use these wheels. AND, I would like to use these center caps The problem i'm having, is that the wheels are take-offs from a Toyota Tacoma. Finding a proper fitting center cap is difficult, so I opted to use those center caps. The trouble I think i'll have, is that the caps are retained by means of the lug nuts. If the cap doesn't quite reach the lug nuts because of the inner diameter wheel clearance, then can you guys offer a suggestion as to what to do to cover the center hub? I'm killing two birds with one stone if I can make this work...Engine RPM, and I can sell my existing tires to pay for new tires for my wife's car.
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
02-22-2016, 05:44 PM | #2 |
1961 crewcab
Re: Crazy Fig is at it again with the A.D.D.
aren't those held on w/ a special lug nut that has threads on the end? can you just make those longer if they don't reach?
I am thinking , 2 sets of nuts, and weld the new set to the end of the others?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-22-2016, 06:35 PM | #3 |
I've seen them on rally wheels. Yes they need the special nuts. Can someone verify the lug nut size, I think it's 7/16",(I verified it myself 7/16"x20). They look snug against the rim in this picture,
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 02-22-2016 at 10:22 PM. |
02-22-2016, 07:21 PM | #4 |
the late model lug nuts that the black plastic nuts screw to are metric
so you would need to change the studs to metric . another idea is no caps just some chrome bullet lug nuts like these . I put these on I couple of my old hotrods that I have. http://www.ebay.com/itm/24-Bullet-Lu...sAAOSw3KFWgaNg |
02-22-2016, 09:53 PM | #5 | |
7/16"- (7/8"hex drive) http://www.ebay.com/itm/331224278660...%3AMEBIDX%3AIT 7/16"- (3/4"hex drive)- http://www.ebay.com/itm/20-Piece-7-1...item35e1e52d20 I don't know which would be correct for those type of cap. 1/2"- http://www.ebay.com/itm/231251036142...%3AMEBIDX%3AIT 9/16"- http://www.ebay.com/itm/231251043543...%3AMEBIDX%3AIT
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 02-24-2016 at 10:16 PM. |
02-22-2016, 10:52 PM | #6 |
Figuarus do the edges hit the rim before it gets deep enough to attach?
How close does it come to fitting? If they didn't have the plastic chrome you could possibly trim the edge back a little. It wouldn't take much of the smaller but it you could get it about 1/4" or so deeper. I think the plastichrome would flake off it you tried.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
02-23-2016, 12:41 AM | #7 |
Slowbuild, thats almost exactly the look im going for.
I dont have the cap yet, but should hopefully have one in the next day or so. Once i have it, ill know more, but if it doesnt ill have to find a way to make them work, or find a chrome push through cap.
02-24-2016, 07:18 PM | #8 |
OK, Well, got the tires mounted and on the truck.
I'm gonna go by a place that may have what I need after work. Either way, This is starting to look better...
02-24-2016, 07:44 PM | #9 |
put some spyder caps on it
02-24-2016, 07:51 PM | #10 |
02-24-2016, 08:59 PM | #11 |
You could run a push through bullet with bullet lugs. Gives a similar look to spider caps.
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
02-24-2016, 09:07 PM | #12 | |
When I did mine, I used a nut that was 7/16-20 for the internal thread and a metric thread on the outside. I got mine from Stockton wheel at the time, not sure if they would be a local buy or not. Those e-bay ones don't specify the other thread size and they should if they are conversion nuts.
02-24-2016, 09:32 PM | #13 |
02-24-2016, 09:33 PM | #14 |
The outer thread for the cap nuts is the same on all of them
02-24-2016, 10:15 PM | #15 |
I guess we will find out soon. I just ordered a set of 24 7/16". I have a set of the same caps, except mine aren't chrome, that I'm going to use with my rallies.
02-25-2016, 06:14 AM | #16 | |
02-27-2016, 08:15 PM | #17 |
They work. I think the plastichrome caps would look better. I like these because they aren't as tall as the old caps so it makes the wheel look deeper in my opinion. They do look more bulky but I like them.
02-27-2016, 09:05 PM | #18 |
Glad they worked out. I'll keep that link handi in case I need more ever.
