02-22-2016, 07:51 PM | #1 |
New bench seat ideas
The seat in my 73 K10 cheyenne has suffered the wrath of a million farts and it's time for a new bench. Any recommendations on what year GM/Chevy I can pull from. I figure I can go into the 80s, but are there any newer truck models that will have a bench that matches up. Wouldn't mind some new age comfort for those long hauls.
Thank you, Doc 1973 Cheyenne "I get up in the morning looking for an adventure." |
02-22-2016, 09:59 PM | #2 |
Re: New bench seat ideas
Rip seat. A million farts is a hell of a total.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
02-22-2016, 10:11 PM | #3 |
I bet mine has upwards of 2 million.
02-22-2016, 10:26 PM | #4 |
a lot of hard work went into that number.
02-22-2016, 10:27 PM | #5 |
02-22-2016, 10:40 PM | #6 |
I just ordered foam and a seat cover, getting ready to redo mine ..
The foam and batting was 127 bucks, custom fabric cover 168 .. considerably less than the 550 I was quoted.
1985 K20 4spd 1978 K20 4spd |
02-22-2016, 10:49 PM | #7 |
that's good to know, and a way better deal. where did you order everything from? you should post some photos of the process.
02-22-2016, 10:56 PM | #8 |
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
02-22-2016, 11:29 PM | #9 | |
www.foambymail.com Bought foam here, and a cover here seatcoversunlimited.com ... They said 3 weeks out, I'll probably take some pics of the process ...
02-23-2016, 03:16 PM | #10 | |
02-26-2016, 02:36 PM | #11 |
bump
03-22-2016, 02:26 AM | #12 |
Any idea what years will interchange with my 1973 easily. Which years will bolt right in?
03-22-2016, 03:27 AM | #13 |
73-87 standard cab but the crew cab ran tell 91 and those can work also.
03-22-2016, 01:40 PM | #14 |
Thank you! any idea what other models/years i can bolt directly? Blazer, Suburban/jimmy, etc?
03-22-2016, 01:44 PM | #15 |
Nothing will really "bolt" in... Hope you have some fab skills.
03-22-2016, 01:47 PM | #16 |
"Nothing" meaning, nothing other than 73-87 k10-30, right?
03-22-2016, 01:55 PM | #17 |
03-22-2016, 03:59 PM | #18 |
Front bench seats from 73-91 Suburban will bolt in if you swap the bench sliders. I had 89 Suburban captain chairs in mine, only required a slight mod to the tracks to bolt in.
03-22-2016, 09:01 PM | #19 |
I would shop around at local upholstery shops and see if they can rebuild and recover your seat for $250 or so. If not, then you will likely have to fabricate new frames for other seats. I plan to put Chrysler Sebring convertible seats in my 83 because I want integrated seat belts and the late model Chevy truck seats with integrated belts sit up too high to work.
03-22-2016, 10:51 PM | #20 |
I love the Square body bench seats, only seats where you can comfortable slide your girl right up next to ya when you are driving. But then again I am kind of old fashioned.
1985 Scotsdale 4x4 Family Tradition Link to build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=699559 |
03-22-2016, 10:57 PM | #21 |
03-23-2016, 09:31 AM | #22 |
I married my girlfriend 26 years ago..Got Suburban buckets now.
03-23-2016, 12:18 PM | #23 | |
I had a 90's seat in my truck (which is an 86) when I bought it and it was the wrong color & wrong model year. I wanted to have a period correct seat, so I found one at at a salvage yard and had it re-upholstered with the correct colors just like it would have been if I had bought the truck new. The Maroon seat is the 90's seat. The blue seat is the one I got from the salvage yard (it is period correct for my truck) and had it re-uphoulstered to the charcoal. |
03-23-2016, 12:21 PM | #24 |
I'm the same way. I'm looking for a a bench, with a center console that can fold down, when it's just me or me and a buddy.
03-23-2016, 06:48 PM | #25 |
Two benefits of the Sebring convertible seats are integral seat belts instead of the clunky stock seat belts we have (which don't seem to work very well, IMHO), and a decent headrest. I am 6'2" and am used to a head rest and adjustable backrest.
