Old 09-23-2003, 12:29 AM   #1
littlee_domn8r
AKA "Hurricane Hank"
littlee_domn8r's Avatar
idiot wants to lose idiot lights
I have an 84 C10 with idiot lights. Can I swap in factory guages from a 76 on up? and is it worth it? I will only do this if I decide to keep it. If someone could share their wisdom, I'd appreciate it.
Myron Hertel
84 C10 LWB 350 4 speed
63 GMC Custom LWB 350 factory auto
littlee_domn8r is offline   Reply With Quote
Old 09-23-2003, 09:59 AM   #2
mjsmith1223
Not sure if the clusters are a direct swap from 76 up. I think from 81 and up they should be. I believe you will also have to change the senders on your engine. Can someone else confirm or deny?
Mike
Grand Haven, MI
1986 GMC C1500 High Sierra w/ mid-70's-ish 350 & th350 tranny
1976 Wellcraft 19.5' cuddy, Chevy 250 I6 -- FOR SALE
mjsmith1223 is offline   Reply With Quote
Old 09-23-2003, 03:00 PM   #3
stan79chevy
stan79chevy's Avatar
76 gauges probably junk
you may be better off just installing brand new guages
stan79chevy is offline   Reply With Quote
Old 09-24-2003, 03:08 AM   #4
tibbar
gauges
The wiring is different from the 70's to the 80's. On my 75 I had to change the inside wiring harness to accomodate for the newer instrument cluster, and then the senders as well, It will be prety much the same going the other direction. Good luck. Tibbar
tibbar is offline   Reply With Quote
Old 09-25-2003, 09:44 AM   #5
stan79chevy
i went mechanical
mechanical gauges are pretty easy to install. i just had to cut a hole in the back of the cluster to run the lines out, send a hot wire over for the lights and your done
Old 09-26-2003, 12:56 AM   #6
junkyardpartseeker
mechanical
I got a gauge cluster from a 84 truck to install in my 84 suburban with the lights. I thought they would direct plug up and go. Found out I had to pull the whole under dash harness to install with it, and change the sending units.
It's a chore to do.
Tommy
junkyardpartseeker is offline   Reply With Quote
Old 09-26-2003, 06:49 AM   #7
swervin ervin
You get what you pay for
swervin ervin's Avatar
When changing from lights to gauges, it's not all that hard. All you need to do is get the harness plug with the gauge cluster. Then cut your plug off and rewire in the new plug. All the wires are the same color, just in a different location on the plug. I did this very same thing on my 87 van.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
